はじめに
Use this guide to replace the rear camera lens on your Huawei Ascend W1. This guide will show you how to remove the old scratched or broken lens. Remember to be careful when removing all the parts and make sure to keep track of the pieces once they are removed.
パーツ
パーツは必要ありません。
  1. Flip the device over so that the back of the phone is facing you and the screen is against your palm.
    • Flip the device over so that the back of the phone is facing you and the screen is against your palm.
  2. Locate the slit at the bottom of the back cover.
    • Locate the slit at the bottom of the back cover.
    • Using your fingernail, lift up on the back cover to expose the battery.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Lift the back cover off the phone.
    • Lift the back cover off the phone.
    • The back cover is snapped onto the phone so you will feel it unsnapping as you remove it.
  5. Find the indented notch at the base of the battery. Lift the battery out of the phone with your fingers by pressing forward and lifting upward. Lift the battery out of the phone with your fingers by pressing forward and lifting upward.
    • Find the indented notch at the base of the battery.
    • Lift the battery out of the phone with your fingers by pressing forward and lifting upward.
  6. After removing the battery, remove the 2mm screws using a T5 Torx screwdriver. There are eleven screws that hold the middle cover to the rest of the phone.
    • After removing the battery, remove the 2mm screws using a T5 Torx screwdriver.
    • There are eleven screws that hold the middle cover to the rest of the phone.
  7. Use tweezers to gently press against the back of the lens from the back of the frame. Use tweezers to pry off the lens from the front of the frame.
    • Use tweezers to gently press against the back of the lens from the back of the frame.
    • Use tweezers to pry off the lens from the front of the frame.
まとめ
Tanner Cline
メンバー登録日: 2018年11月01日
169 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S3-G2, Harley Fall 2018 IUPUI, Team S3-G2, Harley Fall 2018人のメンバー
IUPUI-HARLEY-F18S3G2
3 メンバー
2のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 43
