メインコンテンツにスキップ
Huawei Ascend W1 Antenna Replacement
必要な工具と部品
  1. Huawei Ascend W1 Antenna Replacement, The phone's orientation.: 手順 1、 1の画像 1
    • Flip the device over so that the back of the phone is facing you and the screen is against your palm.
  2. Huawei Ascend W1 Antenna Replacement, Removing the back cover.: 手順 2、 1の画像 1
    • Locate the slit at the bottom of the back cover.
    • Using your fingernail, lift up on the back cover to expose the battery.
  3. Huawei Ascend W1 Antenna Replacement: 手順 3、 1の画像 1
    • Lift the back cover off the phone.
    • The back cover is snapped onto the phone so you will feel it unsnapping as you remove it.
  4. Huawei Ascend W1 Antenna Replacement, Removing the battery.: 手順 4、 3の画像 1 Huawei Ascend W1 Antenna Replacement, Removing the battery.: 手順 4、 3の画像 2 Huawei Ascend W1 Antenna Replacement, Removing the battery.: 手順 4、 3の画像 3
    • Find the indented notch at the base of the battery.
    • Lift the battery out of the phone with your fingers by pressing forward and lifting upward.
  5. Huawei Ascend W1 Antenna Replacement, Remove all the screws.: 手順 5、 2の画像 1 Huawei Ascend W1 Antenna Replacement, Remove all the screws.: 手順 5、 2の画像 2
    • After removing the battery, remove the screws using a T6 screwdriver.
    • There are eleven screws that hold the middle cover to the rest of the phone.
    • The screw that is marked by the orange circle is covered by a white dot.
  6. Huawei Ascend W1 Antenna Replacement, Removing lower section of the middle cover.: 手順 6、 3の画像 1 Huawei Ascend W1 Antenna Replacement, Removing lower section of the middle cover.: 手順 6、 3の画像 2 Huawei Ascend W1 Antenna Replacement, Removing lower section of the middle cover.: 手順 6、 3の画像 3
    • After all the screws are removed, use your fingers to remove the lower section of the middle cover.
    • Pull the lower section of the middle cover outward towards you, exposing the circuit board underneath.
  7. Huawei Ascend W1 Antenna Replacement, Removing the rest of the middle cover.: 手順 7、 3の画像 1 Huawei Ascend W1 Antenna Replacement, Removing the rest of the middle cover.: 手順 7、 3の画像 2 Huawei Ascend W1 Antenna Replacement, Removing the rest of the middle cover.: 手順 7、 3の画像 3
    • Begin working your way around the sides of the cover plate, unsnapping it gently.
    • The middle cover is a thin piece of plastic with the external speaker inside of it.
    • Be gentle as you remove circuit cover. The parts might break if you are too forceful.
  8. Huawei Ascend W1 Antenna Replacement, Locating the antenna.: 手順 8、 2の画像 1 Huawei Ascend W1 Antenna Replacement, Locating the antenna.: 手順 8、 2の画像 2
    • The middle covers are removed.
    • The antenna is a thin white wire that connects to the circuit board in two locations.
  9. Huawei Ascend W1 Antenna Replacement, Removing the antenna: 手順 9、 2の画像 1 Huawei Ascend W1 Antenna Replacement, Removing the antenna: 手順 9、 2の画像 2
    • Lift gently at each connector of the white wire to disconnect the antenna from the port.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jaie Hillery
メンバー登録日: 10/07/14
1,718 ポイント
10のガイドは作成済み
チーム
USF Tampa, Team 16-6, Blackwell Winter 2016 USF Tampa, Team 16-6, Blackwell Winter 2016人のメンバー
USFT-BLACKWELL-W16S16G6
3 メンバー
22のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 19
今までの合計 1,303
