はじめに
Replace your phone's cracked screen or unresponsive LCD display to give it a fresh appearance. The screen and LCD display are glued on and wired in place, so replacing this part requires patience. Because the screen and LCD display are one piece, replacing one means you are placing both.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
必要な工具と部品
Pull and twist the pin near the bottom left-side of the phone to remove it from the headphone jack.
Firmly push down on the black plastic covering at the bottom of the phone, and pull down.
Remove the following screws securing the logic board to the main frame:
Five 2mm Phillips #000 screws
Two 2.5mm Phillips #000 screws
To replace the battery only the two orange 2.5mm screws need to be removed in this step.
Jarl Friis - 返信
Use the flat end of a spudger to gently snap open the first clip located on the the right arm of the retaining plate.
Use the flat end of a spudger to gently snap the second clip located on the left arm of the retaining plate.
Use the flat end of a spudger to gently lift the upper retaining plate from the phone.
Remove the two 2mm Phillips #000 screws securing the copper flex cable to the silver metal tab.
Use the pointy end of a spudger to wedge underneath the black circular vibrator motor near the bottom right of the phone.
Slowly lift up to separate the black circular vibrator motor from the adhesive.
Use the pointy end of a spudger to wedge underneath the earpiece speaker, and gently pry upward.
Use tweezers to remove the earpiece speaker from the frame.
Use the pointy end of a spudger to peel back and fold down the black plastic cover near the bottom left of the phone.
Use the iSeasmo tool to wedge between the screen and the plastic near the bottom right corner of the phone. You must wedge the iSeasmo underneath the white plastic part of the screen, and not just the glass.
Run your iSeasmo tool slowly to the left and right to begin separating the display.
Run your iSeasmo tool along the right and left edges of the display.
18 の人々がこのガイドを完成させました。
5 件のコメント
Where did you buy the replacement screen?
To find the screen you are looking for just do a Google search, and you should no problem getting what you need.
After changing the ear piece, my phone refuse to display after putting it on, what could be wrong.
Julius olu - 返信
