はじめに
Replace your phone's Micro-USB flex cable to fix any charging issues.
必要な工具と部品
Pull and twist the pin near the bottom left-side of the phone to remove it from the headphone jack.
Firmly push down on the black plastic covering at the bottom of the phone, and pull down.
Remove the following screws securing the logic board to the main frame:
Five 2mm Phillips #000 screws
Two 2.5mm Phillips #000 screws
Use the flat end of a spudger to gently snap open the first clip located on the the right arm of the retaining plate.
Use the flat end of a spudger to gently snap the second clip located on the left arm of the retaining plate.
Use the flat end of a spudger to gently lift the upper retaining plate from the phone.
Remove the two 2mm Phillips #000 screws securing the copper flex cable to the silver metal tab.
ある他の人がこのガイドを完成しました。
