メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to use a floor jack with the 2010-2017 Suzuki Swift
必要な工具と部品
  1. How to use a floor jack with the 2010-2017 Suzuki Swift, jack up your car: 手順 1、 3の画像 1 How to use a floor jack with the 2010-2017 Suzuki Swift, jack up your car: 手順 1、 3の画像 2 How to use a floor jack with the 2010-2017 Suzuki Swift, jack up your car: 手順 1、 3の画像 3
    • CAUTION: THIS PROCESS IS POTENTIALLY DANGEROUS. Be aware of your surroundings and do not go underneath your vehicle until this step is completed.
    • Make sure the handbrake is on, and the gear is in reverse for manual or park for an automatic transmission car.
    • Follow the safety instructions of the jack stand and jack.
    • Refer to this guide for more detailed information on how to jack up a car.
    • Put the jack under the rear frame hook and jack up the back of the car until the jack stands can be put under the jack supports.
    • Put jack stands under the rear jack supports. Slowly lower the weight of the car onto them by lowering the jack.
    • Put the jack under the front sub frame and jack up the front of the car until the jack stands can be put under the jack supports.
    • Put jack stands under the front jack supports. Slowly lower the weight of the car onto them by lowering the jack.
終わりに
To lower the car, follow these instructions in reverse order.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
knipwim
メンバー登録日: 09/01/18
15,067 ポイント
43のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 58
過去 30 日: 248
今までの合計 6,690
