メインコンテンツにスキップ
How to use a Krone LSA-Plus Punchdown Tool
必要な工具と部品
  1. How to use a Krone LSA-Plus Punchdown Tool, LSA vs. LSA Plus: 手順 1、 2の画像 1 How to use a Krone LSA-Plus Punchdown Tool, LSA vs. LSA Plus: 手順 1、 2の画像 2
    • There is a difference between LSA and LSA Plus:
    • LSA: The insulation displacement terminals are perpendicular to the cable.
    • LSA Plus: With this technology, the insulation displacement connectors are at an angle of 45° to the cable.
  2. How to use a Krone LSA-Plus Punchdown Tool, Switch the scissors on/off: 手順 2、 1の画像 1
    • The Krone tool has integrated scissors that automatically cut the excess when you punch down the wire.
    • To enable or disable the scissors, turn the wheel in the middle of the tool.
  3. How to use a Krone LSA-Plus Punchdown Tool, Switch the sensor on/off: 手順 3、 2の画像 1 How to use a Krone LSA-Plus Punchdown Tool, Switch the sensor on/off: 手順 3、 2の画像 2
    • The sensor is a mechanism that only allows the scissors to work if the tool is properly inserted into the LSA slot. You might want to disable it if you want to connect two wires on one contact (requires special contact).
    • To disable the sensor, move the metal bracket at the front of the tool towards the toolhead.
  4. How to use a Krone LSA-Plus Punchdown Tool, Place your cable: 手順 4、 1の画像 1
    • Place the cable you want to punch down into the terminal.
  5. How to use a Krone LSA-Plus Punchdown Tool, Punch down: 手順 5、 2の画像 1 How to use a Krone LSA-Plus Punchdown Tool, Punch down: 手順 5、 2の画像 2
    • Press down on the connector.
    • LSA-Plus is directionally keyed. If your tool doesn't enter into the gap, it might be because you're holding it the wrong way around.
  6. How to use a Krone LSA-Plus Punchdown Tool, Cut the excess: 手順 6、 1の画像 1
    この手順で使用する道具:
    Flush Cutter
    $29.99
    • If your scissors are off, or you're working in a tight space where the excess left by the tool might be too much you'll have to manually trim the excess.
    • Use electronics sidecutters to trim the excess.
  7. How to use a Krone LSA-Plus Punchdown Tool, Remove a connection: 手順 7、 3の画像 1 How to use a Krone LSA-Plus Punchdown Tool, Remove a connection: 手順 7、 3の画像 2 How to use a Krone LSA-Plus Punchdown Tool, Remove a connection: 手順 7、 3の画像 3
    • Press on the tab to release the wire removal hook.
    • Use the hook to pull out the wire you want to remove.
終わりに
Good luck on your next project!
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Sebastian
メンバー登録日: 08/19/18
31,049 ポイント
71のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 108
過去 30 日: 491
今までの合計 9,767
