メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to turn on your dead, not charging Samsung tab 2
終わりに
12 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
MrSarbine
メンバー登録日: 12/24/15
377 ポイント
1ガイドが承認済み
3件のガイドコメント
I had the same problem with this tablet.
Original charger didn't work, battery symbol appeared and disappeared again and again.
I fixed it in a quite simple way without opening the device.
I remembered that I got a bad charger, very bad, so bad that a conected smartphone won't even work properly, as there is so much high frequency noise on the 5V-output. By means of this noise this very-very-bad charger put the needed extra-portion of energy into the battery, that the device was able to get behind this critical point at startup, that made it switch off before, and charging could be finished with a proper charger.
Problem: solved!
Reinhard Kaune - 返信
Are you saying replacing the charger fixed the issue for you? Or are you saying temporarily using a better charger to get the battery above 5% and then using any charger after that to finish the job fixed the issue?
gatchi -
My tab would be indicating a battery percentage of 46%, and would just shut down. What might be the problem?
chucks oparah - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 40
今までの合計 5,276
