メインコンテンツにスキップ
How to troubleshoot Sony ECM-MS907 sound distortion
必要な工具と部品
  1. How to troubleshoot Sony ECM-MS907 sound distortion, Windscreen Removal and Inspection: 手順 1、 3の画像 1 How to troubleshoot Sony ECM-MS907 sound distortion, Windscreen Removal and Inspection: 手順 1、 3の画像 2 How to troubleshoot Sony ECM-MS907 sound distortion, Windscreen Removal and Inspection: 手順 1、 3の画像 3
    • Remove the windscreen from the top of the microphone.
    • Once the foam windscreen is removed, examine the windscreen looking for thinning, holes, tears, or discoloration. Any of these issues may be the cause of the sound distortion.
  2. How to troubleshoot Sony ECM-MS907 sound distortion, Examine the Jack: 手順 2、 2の画像 1 How to troubleshoot Sony ECM-MS907 sound distortion, Examine the Jack: 手順 2、 2の画像 2
    • Locate the jack of the microphone and look for: discoloration, rust, breaks in the piece, as well as making sure the jack is not bent or torn from the power cord.
  3. How to troubleshoot Sony ECM-MS907 sound distortion, Examining the Cord: 手順 3、 2の画像 1 How to troubleshoot Sony ECM-MS907 sound distortion, Examining the Cord: 手順 3、 2の画像 2
    • Inspect the cord for splits, breaks, or loose wires. Check the cord from one end to the other, making sure the cord is attached to the microphone.
  4. How to troubleshoot Sony ECM-MS907 sound distortion: 手順 4、 3の画像 1 How to troubleshoot Sony ECM-MS907 sound distortion: 手順 4、 3の画像 2 How to troubleshoot Sony ECM-MS907 sound distortion: 手順 4、 3の画像 3
    • To check the cord further by unscrewing the bottom piece of the microphone from the top. Rotate clockwise to unscrew the bottom and examine.
  5. How to troubleshoot Sony ECM-MS907 sound distortion: 手順 5、 3の画像 1 How to troubleshoot Sony ECM-MS907 sound distortion: 手順 5、 3の画像 2 How to troubleshoot Sony ECM-MS907 sound distortion: 手順 5、 3の画像 3
    • Another to assessing distortion is to inspect the diaphragm. For further information, see the Diaphragm Examination Guide
    • Use a Phillips head (#00) screwdriver, to remove the diaphragm and separate the diaphragm from the base of the microphone.
  6. How to troubleshoot Sony ECM-MS907 sound distortion: 手順 6、 3の画像 1 How to troubleshoot Sony ECM-MS907 sound distortion: 手順 6、 3の画像 2 How to troubleshoot Sony ECM-MS907 sound distortion: 手順 6、 3の画像 3
    • Inspect the diaphragm checking to see if the piece is dirty, bent, or has holes. If it is bent or has holes, it may need to be replaced.
    • If the diaphragm is dirty, clean it with a dry towel or cotton swab by gently brushing dirt and/or rust off the piece.
終わりに
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
Justin Lewis
メンバー登録日: 01/23/14
242 ポイント
2のガイドは作成済み
チーム
New Mexico State, Team 1-2, Sheppard Spring 2014 New Mexico State, Team 1-2, Sheppard Spring 2014人のメンバー
NMSU-SHEPPARD-S14S1G2
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 938
