メインコンテンツにスキップ
How to test an Ethernet Cable
必要な工具と部品
  1. How to test an Ethernet Cable, Ports: 手順 1、 2の画像 1 How to test an Ethernet Cable, Ports: 手順 1、 2の画像 2
    • The tester has two ports on each part:
    • RJ11 (6P2C)
    • RJ45 (8P8C)
  2. How to test an Ethernet Cable, Connect the cable: 手順 2、 1の画像 1
    • Connect one end of the cable on one half of the tester each.
    • If you are testing jacks you can just connect them with a known good patch cable.
    • If the other side of your cable is already connected to a switch or some other device you can connect the MASTER device only.
    • Only do this with cable testers you trust, since crappy cable testers might not limit the current they send through the data lines.
  3. How to test an Ethernet Cable, Switch on the tester: 手順 3、 1の画像 1
    • Switch on the tester.
    • The tester has two modes: ON and S. There is no difference in the two modes besides the testing interval on S being more drawn out.
  4. How to test an Ethernet Cable, Test the cable: 手順 4、 1の画像 1
    • The tester will go through all the wires in sequence. If the sequence of the green lights blinking does not line up you might have swapped some wires when wiring the connector.
    • If some lights do not light up there might be a break in the cable or you made a mistake when crimping the connector.
    • For Fast Ethernet (100 Mbit/s) you only need pins 1, 2, 3 and 6. Some cheap cables may not even have more than these four wires.
    • G means ground. For most consumer applications up to 1GbE it should be fine if your ground is not properly connected.
終わりに
Good luck on your next project!
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Sebastian
メンバー登録日: 08/19/18
31,157 ポイント
71のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 14
過去 7 日: 94
過去 30 日: 430
今までの合計 18,644
