メインコンテンツにスキップ
How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables
必要な工具と部品
  1. How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Clean up the ends: 手順 1、 2の画像 1 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Clean up the ends: 手順 1、 2の画像 2
    • Use wire cutters to make a clean cut on the end of the cable you want to strip.
  2. How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Strip the mantle: 手順 2、 2の画像 1 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Strip the mantle: 手順 2、 2の画像 2
    • Grip the cable with a stripping tool for communication cables and twist it to cut the mantle.
    • Pull off the mantle.
    • It depends on what you want to do with the wire, but usually stripping off about 5cm is a pretty good starting point.
  3. How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Remove the shielding: 手順 3、 2の画像 1 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Remove the shielding: 手順 3、 2の画像 2
    この手順で使用する道具:
    Flush Cutter
    $29.99
  4. How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Remove the plastic foil: 手順 4、 2の画像 1 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Remove the plastic foil: 手順 4、 2の画像 2
    この手順で使用する道具:
    Flush Cutter
    $29.99
  5. How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Pull back the grounding wire: 手順 5、 2の画像 1 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Pull back the grounding wire: 手順 5、 2の画像 2
    • Pull back the grounding wire and wrap it around the cable.
  6. How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Strip the wire (optional): 手順 6、 3の画像 1 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Strip the wire (optional): 手順 6、 3の画像 2 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Strip the wire (optional): 手順 6、 3の画像 3
    • Stripping the wire itself is optional, depending on what you want to do with it. P. ex. if you are going to punch it down into an LSA Plus block, you don't need to strip the wire.
    • Grip the wire with the 0.8 mm notch and pull off the insulation or use automatic wire strippers.
    • Stripping off 1cm is usually enough.
終わりに
Good luck on your next project!
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Sebastian
メンバー登録日: 08/19/18
31,049 ポイント
71のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 14
今までの合計 315
