メインコンテンツにスキップ
How to strip Cat.7 S/FTP PiMF Ethernet Cable
必要な工具と部品
  1. How to strip Cat.7 S/FTP PiMF Ethernet Cable, Clean up the ends: 手順 1、 2の画像 1 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Clean up the ends: 手順 1、 2の画像 2
    • Use wire cutters to make a clean cut on the end of the cable you want to strip.
  2. How to strip Cat.7 S/FTP PiMF Ethernet Cable, Strip the mantle: 手順 2、 2の画像 1 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Strip the mantle: 手順 2、 2の画像 2
    • Grip the cable with a stripping tool for communication cables and twist it to cut the mantle.
    • Pull off the mantle.
    • It depends on what you want to do with the wire, but usually stripping off about 5cm is a pretty good starting point.
  3. How to strip Cat.7 S/FTP PiMF Ethernet Cable, Pull back the braided shield: 手順 3、 3の画像 1 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Pull back the braided shield: 手順 3、 3の画像 2 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Pull back the braided shield: 手順 3、 3の画像 3
    • Pull back the grounding mesh and twist it around the first cm of still insulated cable.
    • You can leave the excess, but if you want to cut it, make sure to leave at least about 1cm.
  4. How to strip Cat.7 S/FTP PiMF Ethernet Cable, Spread the twisted pairs: 手順 4、 1の画像 1
    • Spread out the twisted pairs to make them easier to work with.
  5. How to strip Cat.7 S/FTP PiMF Ethernet Cable, Remove the shielding: 手順 5、 2の画像 1 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Remove the shielding: 手順 5、 2の画像 2
    この手順で使用する道具:
    Flush Cutter
    $29.99
    • Unwrap the shielding a bit and nick it at the base with some electronics side cutters.
    • If you will wire this cable in a terminal block instead of a Keystone or crimping on a connector, you should just remove the minimum amount of shielding needed to properly punch down the connection.
    • Make sure to not damage the delicate insulation of the individual wires.
    • Rip off the shielding.
    • Repeat for all four twisted pairs.
  6. How to strip Cat.7 S/FTP PiMF Ethernet Cable, Strip the wire (optional): 手順 6、 3の画像 1 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Strip the wire (optional): 手順 6、 3の画像 2 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Strip the wire (optional): 手順 6、 3の画像 3
    • Stripping the wire itself is optional, depending on what you want to do with it. P. ex. if you are going to punch it down into an LSA Plus block, you don't need to strip the wire.
    • Grip the wire with the 0.3 mm notch and pull off the insulation or use automatic wire strippers.
    • Stripping off 1cm is usually enough.
終わりに
Good luck on your next project!
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Sebastian
メンバー登録日: 08/19/18
31,157 ポイント
71のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 20
過去 30 日: 97
今までの合計 2,725
