メインコンテンツにスキップ
How to stop bicycle brakes from squeaking
必要な工具と部品
  1. How to stop bicycle brakes from squeaking, How to stop bicycle brakes from squeaking: 手順 1、 1の画像 1
    • Loosen the brake pads from the calipers using a 10mm wrench.
    • You will need to repeat this step for the second brake pad located on the other side of the wheel.
  2. How to stop bicycle brakes from squeaking: 手順 2、 1の画像 1
    • Remove the brake pads from the calipers.
  3. How to stop bicycle brakes from squeaking: 手順 3、 1の画像 1
    • Clean the surface of the brake pad with a cloth or water if necessary.
    • The surface of the rims where the brake pads make contact may also need to be cleaned.
  4. How to stop bicycle brakes from squeaking: 手順 4、 1の画像 1
    • Reattach the brake pads to the calipers and tighten them with the 10mm wrench so that the leading edge of the brake sits closer to the rim than the rear edge.
  5. How to stop bicycle brakes from squeaking: 手順 5、 1の画像 1
    • Check the brake cable and make sure that it is still connected and secured to the brake calipers.
  6. How to stop bicycle brakes from squeaking: 手順 6、 1の画像 1
    • Test the brake to ensure that it functions properly before riding the bike.
終わりに
作成者
4人の作成者と共同で作成されました。
Kevin Colon
メンバー登録日: 02/08/18
160 ポイント
1ガイドが承認済み
チーム
Pasco Hernando, Team S5-G34, Prince Spring 2018 Pasco Hernando, Team S5-G34, Prince Spring 2018人のメンバー
PHSC-PRINCE-S18S5G34
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 25
今までの合計 1,636
