メインコンテンツにスキップ
How to shorten shirt straps
必要な工具と部品
  1. How to shorten shirt straps, How to shorten shirt straps: 手順 1、 3の画像 1 How to shorten shirt straps, How to shorten shirt straps: 手順 1、 3の画像 2 How to shorten shirt straps, How to shorten shirt straps: 手順 1、 3の画像 3
    • Put on the shirt.
    • Pull the strap up until you reach your new desired length. Be sure to take the same amount of fabric from the front and the back of the seam.
    • Pin both straps to the desired length.
  2. How to shorten shirt straps: 手順 2、 2の画像 1 How to shorten shirt straps: 手順 2、 2の画像 2
    • Remove the shirt.
    • Be careful of the pins when taking off the shirt.
    • Measure and take a note of the length. Make sure it is the same on both straps.
    • This length will be the amount your strap that will be removed.
  3. How to shorten shirt straps: 手順 3、 3の画像 1 How to shorten shirt straps: 手順 3、 3の画像 2 How to shorten shirt straps: 手順 3、 3の画像 3
    • Remove the pins and flip the shirt inside out.
    • Re-pin both shirt straps. Make sure the pins follow the measurements you just took.
    • Make sure you have a clear line to sew along.
    • Check and make sure the base of the straps are lined up for a continuous edge on your shirt.
  4. How to shorten shirt straps: 手順 4、 3の画像 1 How to shorten shirt straps: 手順 4、 3の画像 2 How to shorten shirt straps: 手順 4、 3の画像 3
    • Thread the sewing machine and set it to your desired stitch length.
    • Refer to your specific sewing machine manual for more guidance.
    • Align the pinned part of the shirt with the needle.
    • Put down the presser foot.
  5. How to shorten shirt straps: 手順 5、 2の画像 1 How to shorten shirt straps: 手順 5、 2の画像 2
    • Sew along the line mapped out by your pins.
    • Pull out the pins as you sew. Make sure not to sew over any of them.
    • If you sew over the pins, you may break the needle.
    • Make sure to backstitch at each end of the seam.
    • Repeat this step for each strap.
  6. How to shorten shirt straps: 手順 6、 1の画像 1
    • Put the shirt back on.
    • Confirm the new length that you chose for the garment.
    • If the straps are too still long or short, carefully rip out your new seam and return to Step 1.
  7. How to shorten shirt straps: 手順 7、 3の画像 1 How to shorten shirt straps: 手順 7、 3の画像 2 How to shorten shirt straps: 手順 7、 3の画像 3
    • Cut excess fabric from the new seams, leaving ¼ inch to ½ inch.
    • Iron the seam allowance left after your cut to the back of the shirt.
  8. How to shorten shirt straps: 手順 8、 1の画像 1
    • Flip the shirt right side out.
    • Make a straight stitch approximately 1/8 inch behind the new shoulder seam on the outside edge.
    • Make sure your new seam properly secures the seam allowance underneath.
  9. How to shorten shirt straps: 手順 9、 1の画像 1
    • Cut any loose threads on the shirt.
終わりに
Your shirt straps now should be secured at their new length.
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Natalie Clark
メンバー登録日: 09/29/15
227 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 15-2, Green Fall 2015 Cal Poly, Team 15-2, Green Fall 2015人のメンバー
CPSU-GREEN-F15S15G2
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 34
今までの合計 10,343
