メインコンテンツにスキップ
How to restring an Acoustic Guitar
必要な工具と部品
  1. How to restring an Acoustic Guitar, Strings: 手順 1、 1の画像 1
    • Twist the 6 knobs in appropriate directions to unstring the guitar.
    • There are six strings on a guitar. From the thickest string to thinest, or left to right, the stings are named E(low), A, D, G, B, and E(high) strings.
    • In order to unstring the strings, turn the knobs for E(low), A, and D strings in clockwise direction and turn the knobs for G, B, E(high) strings in counter clock wise direction.
  2. How to restring an Acoustic Guitar: 手順 2、 2の画像 1 How to restring an Acoustic Guitar: 手順 2、 2の画像 2
    • Carefully remove the pins from the bridge and remove the old strings.
  3. How to restring an Acoustic Guitar: 手順 3、 3の画像 1 How to restring an Acoustic Guitar: 手順 3、 3の画像 2 How to restring an Acoustic Guitar: 手順 3、 3の画像 3
    • Take the new strings out of of the package.
    • Pin the stings onto the bridge, into the pinholes from left to right in the following order; E(low)-A-D-G-B-E(high).
    • Refer to the cover of guitar strings package to distinguish the strings.
  4. How to restring an Acoustic Guitar: 手順 4、 3の画像 1 How to restring an Acoustic Guitar: 手順 4、 3の画像 2 How to restring an Acoustic Guitar: 手順 4、 3の画像 3
    • Insert the end of each string into the head machine.
    • Leave about 1 to 2 inches of string from the head machine and cut it using a clipper.
    • Repeat the process for all six strings.
  5. How to restring an Acoustic Guitar: 手順 5、 1の画像 1
    • Guide the string through the pin hole, so that about 1/3 of an inch of excess string comes out from behind the pin.
    • Turn the knobs in a counterclockwise direction for E(low), A, D strings.
    • Turn the knobs in a clockwise direction for G, B, E(high) strings.
  6. How to restring an Acoustic Guitar: 手順 6、 3の画像 1 How to restring an Acoustic Guitar: 手順 6、 3の画像 2 How to restring an Acoustic Guitar: 手順 6、 3の画像 3
    • Clip the tuner on the head of the guitar and turn it on.
    • Tune each string by plucking the string and checking the letter musical note indicated on the tuner.
    • From left to right, the appropriate musical notes of the strings are, E-A-D-G-B-E
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Brian Yoon
メンバー登録日: 02/23/15
210 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 12-3, Green Winter 2015 Cal Poly, Team 12-3, Green Winter 2015人のメンバー
CPSU-GREEN-W15S12G3
4 メンバー
6のガイドは作成済み
2 件のコメント
Great to know the restring process for acoustic guitar. I am searching for such type of a blog since I need to replace the old string of my guitar and install new strings. The steps mentioned here are very much clear what to do and anyone can easily understand what he/she has to do. I have gone through all the steps and I hope that with the help of these steps I can also able to replace with my newly purchased(https://faberusa.com/product-category/tu... tuner buttons.
netahnpaul86 - 返信
Thanks! I have found this very helpful. But still the fear of replacing the guitar strings is still there lol.
Reid Kaylen - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 17
過去 30 日: 57
今までの合計 7,423
