メインコンテンツにスキップ
How to restore UV Damaged Headlights
必要な工具と部品
  1. How to restore UV Damaged Headlights, How to restore UV Damaged Headlights: 手順 1、 3の画像 1 How to restore UV Damaged Headlights, How to restore UV Damaged Headlights: 手順 1、 3の画像 2 How to restore UV Damaged Headlights, How to restore UV Damaged Headlights: 手順 1、 3の画像 3
    • In a shaded area, apply masking tape on the outer edges of the headlight assembly.
  2. How to restore UV Damaged Headlights: 手順 2、 3の画像 1 How to restore UV Damaged Headlights: 手順 2、 3の画像 2 How to restore UV Damaged Headlights: 手順 2、 3の画像 3
    • Use the spray bottle of soapy water to wet the 800-grit sandpaper.
    • Spray the sandpaper liberally and make sure it is completely wet.
  3. How to restore UV Damaged Headlights: 手順 3、 3の画像 1 How to restore UV Damaged Headlights: 手順 3、 3の画像 2 How to restore UV Damaged Headlights: 手順 3、 3の画像 3
    • Spray the headlight with soapy water and sand the headlight's surface.
    • Continuously spray the headlight and the sandpaper with water. The surface must stay wet during sanding.
    • Sand the headlight in a circular motion throughout this step.
    • Stop sanding when the entire headlight appears foggy.
  4. How to restore UV Damaged Headlights: 手順 4、 3の画像 1 How to restore UV Damaged Headlights: 手順 4、 3の画像 2 How to restore UV Damaged Headlights: 手順 4、 3の画像 3
    • Spray the 2000-grit sandpaper with soapy water and ensure it is completely wet.
    • Sand the headlight in a circular motion while maintaining the surface wet with soapy water.
    • Stop sanding when the headlight appears slightly less cloudy (than in the previous step).
  5. How to restore UV Damaged Headlights: 手順 5、 3の画像 1 How to restore UV Damaged Headlights: 手順 5、 3の画像 2 How to restore UV Damaged Headlights: 手順 5、 3の画像 3
    この手順で使用する道具:
    Microfiber Cleaning Cloths
    $3.99
    • Lightly wet a small section of a clean microfiber cloth with 70% isopropyl alcohol.
    • Rub down the entire headlight surface with the microfiber cloth.
  6. How to restore UV Damaged Headlights: 手順 6、 2の画像 1 How to restore UV Damaged Headlights: 手順 6、 2の画像 2
    • Carefully peel off the old masking tape.
    • Use newspaper to cover the car's body using masking tape to hold it down.
    • Shield any gaps and use newspapers at least a foot long.
    • The newspaper will protect the car from overspray in the next step.
  7. How to restore UV Damaged Headlights: 手順 7、 3の画像 1 How to restore UV Damaged Headlights: 手順 7、 3の画像 2 How to restore UV Damaged Headlights: 手順 7、 3の画像 3
    • Use a clear coat to spray the headlight.
    • Follow the clear coat manufacturer's instructions for spraying distance, number of coats, and drying time.
    • Apply the clear coat in well-ventilated conditions.
  8. How to restore UV Damaged Headlights: 手順 8、 3の画像 1 How to restore UV Damaged Headlights: 手順 8、 3の画像 2 How to restore UV Damaged Headlights: 手順 8、 3の画像 3
    • Apply a small amount of compound to a clean microfiber applicator pad.
    • Dap the headlight's surface with the compound.
    • Work the compound into the headlight.
    • Use heavy pressure and rub in a circular motion when working the compound into the headlight.
  9. How to restore UV Damaged Headlights: 手順 9、 3の画像 1 How to restore UV Damaged Headlights: 手順 9、 3の画像 2 How to restore UV Damaged Headlights: 手順 9、 3の画像 3
    • Wipe the headlight with a clean microfiber cloth.
    • Apply a small amount of polish onto a new, clean microfiber applicator pad.
    • Dap the polish onto the headlight, then work the polish onto the headlight.
  10. How to restore UV Damaged Headlights: 手順 10、 3の画像 1 How to restore UV Damaged Headlights: 手順 10、 3の画像 2 How to restore UV Damaged Headlights: 手順 10、 3の画像 3
    • Wipe the headlight with the clean side of a microfiber cloth.
    • Use a microfiber cloth to scoop about a quarter-sized amount of wax.
    • Rub the wax into the headlight with medium pressure and in a circular motion.
    • Continue rubbing until there is no more visible wax.
  11. How to restore UV Damaged Headlights: 手順 11、 3の画像 1 How to restore UV Damaged Headlights: 手順 11、 3の画像 2 How to restore UV Damaged Headlights: 手順 11、 3の画像 3
    • Wipe the headlight with a clean side of microfiber cloth.
    • Carefully remove the newspaper and masking tape.
    • Enjoy the clear road with your newly restored headlights!
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Patrick Abelgas
メンバー登録日: 10/24/23
277 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 9-1, Ribeiro Fall 2023 CSU Los Angeles, Team 9-1, Ribeiro Fall 2023人のメンバー
Community
3 メンバー
2のガイドは作成済み
1件のガイドコメント
Greetings and thank you for such a comprehensive guide on cleaning the head lights of a vehicle
Peter Jafta - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 22
過去 30 日: 101
今までの合計 1,741
