メインコンテンツにスキップ
How to reset Cisco 7940 / 7960 IP phone to factory defaults
必要な工具と部品
    • In order to perform a factory reset of a phone if the password is set, complete these steps: 1. Unplug the power cable from the phone, and then plug in the cable again. The phone begins its power up cycle.
    • 2. Immediately press and hold # and while the Headset, Mute, and Speaker buttons begin to flash in sequence, release #. The Headset, Mute, and Speaker buttons flash in sequence in order to indicate that the phone waits for you to enter the key sequence for the reset.
    • 3. Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash. If you repeat a key within the sequence, for example, if you press 1223456789*0#, the sequence is still accepted and the phone resets.
    • If you do not complete this key sequence or do not press any keys, after 60 seconds, the Headset, Mute, and Speaker buttons no longer flash, and the phone continues with its normal startup process. The phone does not reset. If you enter an invalid key sequence, the buttons no longer flash, and the phone continues with its normal startup process.
    • If you enter this key sequence correctly, the phone displays this prompt: Keep network cfg? 1 = yes 2 = no
    • In order to reset the network configuration settings when the phone resets, press 2.
    Not working I hold # the headset button is green for a while the mute lights up red release phone sez configuring vlan.. . If I wait when mute turns red headset never lights up and phone sez configuring vlan
    Art A - 返信
ゴール
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Goulithum
メンバー登録日: 01/09/15
1,534 ポイント
2のガイドは作成済み
チーム
Sage Electronics Sage Electronics人のメンバー
Business
3 メンバー
3のガイドは作成済み
コメント 1 件
Just follow the easy steps, and it is reset within a minute or two.
Anders Busk - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 40
今までの合計 27,160
