メインコンテンツにスキップ
How to replace the touch IC on the home button
必要な工具と部品
    • In this tutorial you will learn about fixing the home button in an iPhone 7. To find out more about iPhone repair and more check my other guides!
終わりに
18 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Alex Sander
メンバー登録日: 02/28/17
38,195 ポイント
202のガイドは作成済み
11 件のコメント
Do you have clear instructions and tools how to do it
Abbigail huari - 返信
So do you need to move the chip to replace the home button?
Dylan McGarrity - 返信
You need to reball or replace the chip to repair Touch ID.
Alex Sander -
If the home button or its flex cable is broken then it's completely shot, short of taking it to an Apple store for a replacement.
On the other hand, it could also be caused by the home button's extension flex cable running through the back of the lcd, and/or a damaged camera/speaker flex cable on top. So make sure to check all those out carefully before resorting to the Apple store.
After reading through a lot of suggestions, here's one which sounded interesting to me. Low and behold, this solution has actually worked!! I have removed that single screw completely, restarted the phone, and the home button started working perfectly.
05/31/2017 by screensaviors
I loosened the screw behind the center of the home button (holding it to the metal bracket), and it magically works now. This may not fix a lot of them, but it worked for me. I was just tightening that screw snug, but must have been too snug.
billa.4you - 返信
Very good points, it will certainly help people to resolve some of their problems, thanks for sharing your experience!
Alex Sander -
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 29
過去 30 日: 109
今までの合計 35,642
