メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to replace the screen protector on your phone
必要な工具と部品
    • Slide the phone out of its protective case.
    • Clean the case with warm water and a small amount of mild soap, then allow it to dry completely.
    FixBotに聞いてみる
    コメントを追加
    • Rub a soft pencil eraser gently across the earpiece grill to pull out packed dirt.
    • Shape the eraser tip to a point or cut it flat to reach between the mesh openings.
    • Avoid pressing hard to prevent damaging the speaker.
    FixBotに聞いてみる
    コメントを追加
    • Wipe the screen and body with a microfiber cloth lightly moistened with cleaning alcohol.
    • Work around the edges until all visible smudges disappear.
    • Use alcohol rather than window cleaner because it evaporates quickly and will not harm components.
    FixBotに聞いてみる
    コメントを追加
    • Dip a cotton swab in alcohol, press off excess, then lightly sweep around buttons, speakers, and the charging port.
    • Flatten the swab tip or use a blunted wooden toothpick to fit into narrow openings.
    • Stay shallow and avoid poking deep inside speakers or ports.
    FixBotに聞いてみる
    コメントを追加
    • Turn off fans and avoid activities that stir up lint or dust in the room.
    • Keep calm and patient; a clean environment and steady hands give the best results.
    FixBotに聞いてみる
    コメントを追加
    • Hook a fingernail under one corner of the old protector and peel it away from the display.
    FixBotに聞いてみる
    コメントを追加
    • Use the moist wipe supplied in the protector kit to thoroughly clean the display, especially around the bezels.
    FixBotに聞いてみる
    コメントを追加
    • Buff the glass with the dry wipe from the kit until all moisture is gone.
    • Follow with a high quality microfiber cloth to polish the surface without leaving lint.
    • Use only clean cloths that have not been washed with fabric softener to avoid oily residue.
    • Tilt the phone and inspect; the screen must be completely free of dust and fingerprints.
    FixBotに聞いてみる
    コメントを追加
    • Tap the supplied dust-removal sticker across the display to pick up any last specks.
    • Stick the tape on your work surface so you can reuse it if dust sneaks under the glass later.
    FixBotに聞いてみる
    コメントを追加
    • Peel the film from the side marked for the screen to reveal the adhesive surface.
    • If a speck lands on the adhesive, dab it away with the dust-removal sticker.
    FixBotに聞いてみる
    コメントを追加
    • Position the glass over the display so the cut-outs align with the camera and sensors.
    • Lower the protector slowly onto the screen.
    FixBotに聞いてみる
    コメントを追加
    • Press the center of the protector so the adhesive spreads to the edges.
    • Wrap a microfiber cloth around a finger and push any air pockets toward the sides until they disappear.
    FixBotに聞いてみる
    コメントを追加
    • Give the glass a final wipe, then snap the phone back into its clean, dry case.
    FixBotに聞いてみる
    コメントを追加
終わりに
Your phone now sports a spotless, perfectly aligned screen protector, ready to guard the display against daily wear and accidental drops. Keep the dust-removal sticker handy for quick touch-ups, and enjoy a crystal-clear view.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Ula Gantar
メンバー登録日: 01/08/25
16,609 ポイント
81のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 17
過去 7 日: 88
過去 30 日: 416
今までの合計 2,251
