メインコンテンツにスキップ
How to replace the Nintendo 2DS charging port
必要な工具と部品
ビデオの概要
  1. How to replace the Nintendo 2DS charging port, Battery: 手順 1、 1の画像 1
    • Remove the two Phillips captive screws securing the upper rear panel.
    • The captive screws will not completely detach from the back panel.
  2. How to replace the Nintendo 2DS charging port: 手順 2、 2の画像 1 How to replace the Nintendo 2DS charging port: 手順 2、 2の画像 2
    • Hinge the upper rear panel upwards and outwards to remove it.
  3. How to replace the Nintendo 2DS charging port: 手順 3、 3の画像 1 How to replace the Nintendo 2DS charging port: 手順 3、 3の画像 2 How to replace the Nintendo 2DS charging port: 手順 3、 3の画像 3
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
  4. How to replace the Nintendo 2DS charging port, Rear Panel: 手順 4、 1の画像 1
    • Remove the ten Phillips screws attaching the rear panel.
  5. How to replace the Nintendo 2DS charging port: 手順 5、 1の画像 1
    • The rear panel is attached to the motherboard by a ribbon cable, so be careful not to lift the rear panel too far from the device.
    • Carefully pull the rear panel straight up from the device.
  6. How to replace the Nintendo 2DS charging port: 手順 6、 1の画像 1
    • Use your fingernail or the flat end of a spudger to flip up the connector securing the ribbon cable to the motherboard
    • Remove the cable from the connector
    • Take the opportunity to remove the Left and Right triggers, they have hinges that may break and springs that may jump away.
  7. How to replace the Nintendo 2DS charging port, Remove Side Panels: 手順 7、 2の画像 1 How to replace the Nintendo 2DS charging port, Remove Side Panels: 手順 7、 2の画像 2
    • Hold the side panels of the device's case with your fingers and pull outward to remove them.
    • The panels should come off easily with little force required.
    • There are three ribbon cables which have already been unplugged in this picture, disconnect these before disassembling the device further.
  8. How to replace the Nintendo 2DS charging port, Unscrew Motherboard: 手順 8、 1の画像 1
    • Remove the 12 brass-colored Phillips screws securing the main board.
    • Be very careful not to strip any of these screws. Stripping can occur very easily, and may make replacement of the motherboard impossible.
    • The circle pad has disappeared in this picture. Don't worry, we'll deal with that in the next step
  9. How to replace the Nintendo 2DS charging port, Remove Top Panel: 手順 9、 3の画像 1 How to replace the Nintendo 2DS charging port, Remove Top Panel: 手順 9、 3の画像 2 How to replace the Nintendo 2DS charging port, Remove Top Panel: 手順 9、 3の画像 3
    • The top panel can only be removed when the mother board is not secured.
    • There are two additional screws located on the top rail. Remove these to fully remove the buttons and top rail.
    • There are two screws holding down the joystick base that must be removed. (Be careful of the ribbon cable—it stays connected!)
    • Hold the top panel with your fingers and pull away from the device to remove it.
    • The top panel should come off easily, with very little force applied.
  10. How to replace the Nintendo 2DS charging port, Remove Motherboard: 手順 10、 2の画像 1 How to replace the Nintendo 2DS charging port, Remove Motherboard: 手順 10、 2の画像 2
    • Detach the 2 ribbon cables by lifting the black flip connectors that hold them.
    • Lift out the rectangular board seated in the face and lift out the white square which is the joystick motor (takes a little effort). Both stay attached to the motherboard.
    • On some models, you'll need to remove three more tiny ribbon cables at the bottom of the screen. They are secured by flip up connectors. BE GENTLE!
    • Holding the motherboard on either side, lift to remove it.
  11. How to replace the Nintendo 2DS charging port, Charging Port: 手順 11、 2の画像 1 How to replace the Nintendo 2DS charging port, Charging Port: 手順 11、 2の画像 2
    • Desolder and remove the charging port
    • Don't try to force the port off the board. If it's not coming off, the solder isn't fully melted
  12. How to replace the Nintendo 2DS charging port: 手順 12、 1の画像 1
    • Set the new port in the board, then solder it in place
終わりに
To reassemble your device, follow these instructions in reverse order, starting at step 10
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Nick Myers
メンバー登録日: 04/15/18
3,410 ポイント
22のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 68
過去 30 日: 291
今までの合計 4,917
