はじめに
If the buckle on your Aqua Back bike bag is broken, it can be easily replaced. We show you the steps necessary to replace it.
"These are instructions for Aqua Back bike bags purchased in the Summer Season 2017 or later. Instructions for older models (pre-2017) can be found here."
必要な工具と部品
To remove the broken buckle, you will need a large flat head screwdriver.
Please note: This buckle can only be ordered from our repair workshop. The bottom hf-welded section is also replaceable, but this can only be done in the repair workshop itself.
Finished! You did it.
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
