メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
How to repair an iPhone that won't charge - Tristar Replacement
必要な工具と部品
  1. How to repair an iPhone that won't charge - Tristar Replacement, Check for a new charger: 手順 1、 1の画像 1
    • Your cable could be bad, try a new one, possibly MFI certified ! (Made For iPhone) Or try a known-good one.
    • Try a new charging brick, or a known-good one that delivers at least 5V-1A
  2. How to repair an iPhone that won't charge - Tristar Replacement, Checking the charging port: 手順 2、 1の画像 1
    • Check your charging port, it could be really dirty or ubstructed
    • If it looks dirty, you can take the risk to insert a thin tool and try to pry out the dirt. I am not responsible for the harm you could do to your phone !
  3. How to repair an iPhone that won't charge - Tristar Replacement, Try known-good internals: 手順 3、 1の画像 1
    • Try a known-good battery. Replace it if your phone charges again.
    • Try a known-good Lightning charging port. Replace it if your phone charges again.
    • I know, this is a picture of an iPhone 7, check the video for the 6S on the next step.
    • The whole french version of the process, video does help if you are an english-speaker !
  4. How to repair an iPhone that won't charge - Tristar Replacement, Now some real challenge: 手順 5、 2の画像 1 How to repair an iPhone that won't charge - Tristar Replacement, Now some real challenge: 手順 5、 2の画像 2
    • If you are still reading, bad news, you probably have a motheboard problem !
    • It's probably U4500, or Tristar that's causing it, it fails very frequently on iPhones. You'll have to replace it.
    • Video tutorial for Tristar replacement on iPhone 6S
終わりに
12 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Alexandre Isaac
メンバー登録日: 04/07/13
2,863 ポイント
8のガイドは作成済み
チーム
The Repair Academy The Repair Academy人のメンバー
Business
1 メンバー
20のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 16
過去 30 日: 102
今までの合計 10,954
