メインコンテンツにスキップ
How to repair a hole in a crochet dishcloth
必要な工具と部品
  1. How to repair a hole in a crochet dishcloth, How to repair a hole in a crochet dishcloth: 手順 1、 1の画像 1
    • Collect the tools and materials you'll need.
  2. How to repair a hole in a crochet dishcloth: 手順 2、 3の画像 1 How to repair a hole in a crochet dishcloth: 手順 2、 3の画像 2 How to repair a hole in a crochet dishcloth: 手順 2、 3の画像 3
    • Identify any loose loops that may come undone if any yarn is pulled.
    • Put a safety pin through the loops, this will prevent the hole from getting any bigger.
  3. How to repair a hole in a crochet dishcloth: 手順 3、 3の画像 1 How to repair a hole in a crochet dishcloth: 手順 3、 3の画像 2 How to repair a hole in a crochet dishcloth: 手順 3、 3の画像 3
    • Pick one of the loose strands and tie the yarn to this strand.
    • Make three knots to ensure the knot will not come undone.
  4. How to repair a hole in a crochet dishcloth: 手順 4、 3の画像 1 How to repair a hole in a crochet dishcloth: 手順 4、 3の画像 2 How to repair a hole in a crochet dishcloth: 手順 4、 3の画像 3
    • Begin your first stitch by pushing the crochet hook through the stitch closest to the tied on yarn.
    • Next, wrap the yarn in front of the hook and pull it through the stitch making sure the hook catches the yarn.
  5. How to repair a hole in a crochet dishcloth: 手順 5、 3の画像 1 How to repair a hole in a crochet dishcloth: 手順 5、 3の画像 2 How to repair a hole in a crochet dishcloth: 手順 5、 3の画像 3
    • Continuing on your first stitch, wrap the yarn in front of the hook and pull it in the direction of the arrow through the loop wrapped around the crochet hook.
    • Move on to the next stitch where the orange arrow is pointing. Continue making stitches around the hole until there is a small opening.
  6. How to repair a hole in a crochet dishcloth: 手順 6、 3の画像 1 How to repair a hole in a crochet dishcloth: 手順 6、 3の画像 2 How to repair a hole in a crochet dishcloth: 手順 6、 3の画像 3
    • Once you have a small opening you will now close the hole. Using the same stitch used throughout the guide, make a stitch interlocking every other stitch.
    • The crochet hook should be moving in the direction the arrow is pointing.
  7. How to repair a hole in a crochet dishcloth: 手順 7、 3の画像 1 How to repair a hole in a crochet dishcloth: 手順 7、 3の画像 2 How to repair a hole in a crochet dishcloth: 手順 7、 3の画像 3
    • Continuing until the hole is completely closed.
    • Cut the yarn leaving about a 4 inch tail.
    • Pull the loop in the direction the arrow is pointing.
  8. How to repair a hole in a crochet dishcloth: 手順 8、 3の画像 1 How to repair a hole in a crochet dishcloth: 手順 8、 3の画像 2 How to repair a hole in a crochet dishcloth: 手順 8、 3の画像 3
    • Using the large threading needle, thread in all of the strands of yarn.
終わりに
作成者
2人の作成者と共同で作成されました。
Rayme Ivers
メンバー登録日: 05/04/20
157 ポイント
1ガイドが承認済み
チーム
UW Tacoma, Team S1-G8, Cardinal Spring 2020 UW Tacoma, Team S1-G8, Cardinal Spring 2020人のメンバー
UWT-CARDINAL-S20S1G8
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 50
今までの合計 2,918
