メインコンテンツにスキップ
How to repair a broken seam
必要な工具と部品
  1. How to repair a broken seam, Identify the damaged seam: 手順 1、 3の画像 1 How to repair a broken seam, Identify the damaged seam: 手順 1、 3の画像 2 How to repair a broken seam, Identify the damaged seam: 手順 1、 3の画像 3
    • Locate the damaged area of your item.
    • Check how it looks on the outside, and whether it is spreading further by gently pulling the seam.
    • Also check how the damage looks on the inside, and take note of the type of stitching, and fabric condition around the seam.
  2. How to repair a broken seam, Prepare & repair: 手順 2、 3の画像 1 How to repair a broken seam, Prepare & repair: 手順 2、 3の画像 2 How to repair a broken seam, Prepare & repair: 手順 2、 3の画像 3
    • Prepare and clean the area around the damaged seam by removing broken thread and trimming any loose threads.
    • Prepare the damaged seam by placing the fabric edge to edge.
    • Place the item under the sewing machine, and make a short back-and-forth lockstitch using the reverse lever, to secure one end. Then proceed to make a single long stitch along the seam until the end of the damage. Secure at the end with another locking stitch. Inspect the repair, and if it requires another long stitch, repeat the process.
    • Tip: check the iFixit basic sewing skills page for more tips on sewing machine setup.
  3. How to repair a broken seam, Finished and ready!: 手順 3、 3の画像 1 How to repair a broken seam, Finished and ready!: 手順 3、 3の画像 2 How to repair a broken seam, Finished and ready!: 手順 3、 3の画像 3
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
終わりに
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
作成者
3人の作成者と共同で作成されました。
Ben Blischke
メンバー登録日: 07/19/23
10,230 ポイント
66のガイドは作成済み
チーム
INTERSPORT INTERSPORT人のメンバー
Community
25 メンバー
169のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 60
今までの合計 977
