メインコンテンツにスキップ
How to repair a bikini underwire
必要な工具と部品
  1. How to repair a bikini underwire, Prepare the repair: 手順 1、 3の画像 1 How to repair a bikini underwire, Prepare the repair: 手順 1、 3の画像 2 How to repair a bikini underwire, Prepare the repair: 手順 1、 3の画像 3
    • Identify the defective underwire
    • Push it back into the hem tunnel by hand
  2. How to repair a bikini underwire, Stitching: 手順 2、 3の画像 1 How to repair a bikini underwire, Stitching: 手順 2、 3の画像 2 How to repair a bikini underwire, Stitching: 手順 2、 3の画像 3
    • Prepare the needle and the thread.
    • Starting on one side of the hem tunnel, stitch all along the tunnel opening to close the hole.
    • Repeat the process 1-2 times to make the repair extra durable.
  3. How to repair a bikini underwire, Tie-off the repair: 手順 3、 3の画像 1 How to repair a bikini underwire, Tie-off the repair: 手順 3、 3の画像 2 How to repair a bikini underwire, Tie-off the repair: 手順 3、 3の画像 3
    • Finish the stitching with a knot. Cut the thread.
    • The tunnel is closed, and the underwire will stay inside.
    • Test the repair by pushing and stretching the item gently, to see whether the underwire is straining the repair. If needed, repeat step 2.
  4. How to repair a bikini underwire, Finished and ready!: 手順 4、 1の画像 1
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
終わりに
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
作成者
2人の作成者と共同で作成されました。
Ben Blischke
メンバー登録日: 07/19/23
10,230 ポイント
66のガイドは作成済み
チーム
INTERSPORT INTERSPORT人のメンバー
Community
25 メンバー
169のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 31
今までの合計 660
