メインコンテンツにスキップ
How to repair a Snag in Knit Clothing
必要な工具と部品
  1. How to repair a Snag in Knit Clothing, How to repair a Snag in Knit Clothing: 手順 1、 1の画像 1
    • Pull a stringed needle through the loop of the snag.
  2. How to repair a Snag in Knit Clothing: 手順 2、 1の画像 1
    • Tie a knot at the end of the snag loop.
  3. How to repair a Snag in Knit Clothing: 手順 3、 1の画像 1
    • Put the needle at the base of the snag.
    • Push the needle through the base to the other side.
  4. How to repair a Snag in Knit Clothing: 手順 4、 1の画像 1
    • Flip your clothing item over or inside out to see where the needle was pushed through.
    • Pull the needle all the way through. You want it tight enough that you have the whole snag through, but not tight enough to start pulling through more of the clothing item.
  5. How to repair a Snag in Knit Clothing: 手順 5、 1の画像 1
    • Tie a knot at the base of the snag.
    • Remember: This is is after you pushed the thread to the inside of your clothing. This pushed the snag to the inside. On the inside snag is where you're tying the new knot where it is coming through.
    • Double knot it for extra security.
  6. How to repair a Snag in Knit Clothing: 手順 6、 1の画像 1
    • Cut the extra snag and thread off, leaving a little string near the knot. This leaves a little "tail". Do not cut off the knot or "tail".
    • The small knot and "tail" makes sure the snag doesn't pull through again. If cut, it could unravel the clothing item.
ゴール
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Samantha Bolduc
メンバー登録日: 10/27/15
203 ポイント
1ガイドが承認済み
チーム
Missouri Western, Team 1-1, Adkins Fall 2015 Missouri Western, Team 1-1, Adkins Fall 2015人のメンバー
MWSU-ADKINS-F15S1G1
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 22
今までの合計 2,930
