メインコンテンツにスキップ
How to remove top vent of Winix C535
必要な工具と部品
  1. How to remove top vent of Winix C535, Locating the tabs: 手順 1、 1の画像 1
    • I suggest starting from the middle, popping it out just a tiny bit and move outwards to the sides
    • Apply a small constant lift should make removing this easier. Similar to disassembling other plastic encasements.
  2. How to remove top vent of Winix C535, Taking it out: 手順 2、 2の画像 1 How to remove top vent of Winix C535, Taking it out: 手順 2、 2の画像 2
    • It pulls towards you a little bit to loosen up and then comes out by moving it forward once it's in this position.
    • Clean the vent and reassemble by inserting it from the bottom first and then clicking in the tabs in the front.
  3. How to remove top vent of Winix C535, Done: 手順 3、 1の画像 1
    • Well that was easy wasn't it? Back to making it eat wildfire smoke and whatnot when the time comes.
    • Also do keep in mind that "PlasmaWave" is an ionizing tech which creates ozone in small amounts (regardless of what manufacturer says), so don't use it that often. If you do, you need to air out the room/house when the outside air is cleaner.
終わりに
作成者
1人の作成者と共同作成されました。
Ray
メンバー登録日: 01/21/21
97 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 81
今までの合計 471
