メインコンテンツにスキップ
How to remove the 2010-2017 Suzuki Swift front bumper
必要な工具と部品
  1. How to remove the 2010-2017 Suzuki Swift front bumper, remove the top fasteners: 手順 1、 3の画像 1 How to remove the 2010-2017 Suzuki Swift front bumper, remove the top fasteners: 手順 1、 3の画像 2 How to remove the 2010-2017 Suzuki Swift front bumper, remove the top fasteners: 手順 1、 3の画像 3
    • Open the hood and unscrew the 10mm bolts located at the top.
    • Unscrew the screw located at the side top corner under the fender, repeat on the other side.
  2. How to remove the 2010-2017 Suzuki Swift front bumper, remove bottom fasteners: 手順 2、 3の画像 1 How to remove the 2010-2017 Suzuki Swift front bumper, remove bottom fasteners: 手順 2、 3の画像 2 How to remove the 2010-2017 Suzuki Swift front bumper, remove bottom fasteners: 手順 2、 3の画像 3
    • Unscrew 4 screws located underneath the front of the front bumper.
    • With the flathead, unclip the 2 push rivets underneath the side of the front bumper, disconnecting each fender from the bumper.
    • Repeat on the other side.
  3. How to remove the 2010-2017 Suzuki Swift front bumper, detach top corners: 手順 3、 2の画像 1 How to remove the 2010-2017 Suzuki Swift front bumper, detach top corners: 手順 3、 2の画像 2
    • Gently, pull the side corner loose.
    • Pull from the car and slightly downwards to detach the remaining corner.
  4. How to remove the 2010-2017 Suzuki Swift front bumper, unlatch the bumper: 手順 4、 2の画像 1 How to remove the 2010-2017 Suzuki Swift front bumper, unlatch the bumper: 手順 4、 2の画像 2
    • If your car has fog lights, make sure you disconnect them from the car's wiring.
    • The bumper is now only attached with 2 clips at the top.
    • Push the front of each clip towards the car and unlatch it.
  5. How to remove the 2010-2017 Suzuki Swift front bumper, remove the bumper: 手順 5、 3の画像 1 How to remove the 2010-2017 Suzuki Swift front bumper, remove the bumper: 手順 5、 3の画像 2 How to remove the 2010-2017 Suzuki Swift front bumper, remove the bumper: 手順 5、 3の画像 3
    • Hold the bumper in the center and remove it by moving it down and outwards.
    • The bumper wraps around the bottom and fender parts, take care not to damage anything when removing the bumper.
    • Some of the 4 bottom nut clips might move or detach entirely when removing the bumper. Ensure these are at their correct positions.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
knipwim
メンバー登録日: 09/01/18
8,311 ポイント
30のガイドは作成済み
2 件のコメント
In mine there were also two screws at the corners featured in step 3 that needed removing.
Thomas Bell - 返信
Other screws than you need to remove in step 1 photo 2/3?
knipwim -
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 66
過去 30 日: 274
今までの合計 4,070
