メインコンテンツにスキップ
はじめに
In this guide I will show you how to remove scratches from a glass sapphire watch face without the expense of having to replace your entire watch face.
Just because your watch face is scratched or has many scratches, save yourself from buying a new $80 watch face replacement.
パーツ
パーツは指定されていません。
  1. How to remove scratches from a Breitling Navitimer sapphire watch face, How to remove scratches from a Breitling Navitimer sapphire watch face: 手順 1、 1の画像 1
    • NOTICE THE HORRIBLE SCRATCH ON MY BREITLING NAVITIMER AROUND THE 12 HAND, it's actually a borderline crack.
    • You WILL NEED all of the following: diamond paste - 3 different grades
    • A hand held Dremel tool using felt tip. You can try to use a papertowel and buff the face but it doesn't knock out the job like a Dremel. I bought mine at Walmart for $25 dollars.
  2. How to remove scratches from a Breitling Navitimer sapphire watch face: 手順 2、 3の画像 1 How to remove scratches from a Breitling Navitimer sapphire watch face: 手順 2、 3の画像 2 How to remove scratches from a Breitling Navitimer sapphire watch face: 手順 2、 3の画像 3
    • First, remove your watch band from your watch.
    • After you have removed your watch band from the watch case. Next step is to remove the bezel from the casing.
    • Take butter knife from your kitchen and slide it between the watch case and bezel and pry it up as you twist. You will feel a pop and the bezel will be freed from the watch case.
    • Place your watch dial in the watch case under a cup or dust protector to avoid getting dust and lint on your watch.
  3. How to remove scratches from a Breitling Navitimer sapphire watch face: 手順 3、 2の画像 1 How to remove scratches from a Breitling Navitimer sapphire watch face: 手順 3、 2の画像 2
    • Rather than removing the glass from the bezel, I just left it in. It is advisable to always remove the glass completely, but I did not as the materials being used will not harm the bezel. Exercise caution and do not rush yourself.
    • You will have three different grade diamond pastes. I use a 6, 3, 1... It's always better to do a 6, 3, .25
    • The lowest grade diamond paste is good for refinishing with a glossy mirror finish.
  4. How to remove scratches from a Breitling Navitimer sapphire watch face: 手順 4、 3の画像 1 How to remove scratches from a Breitling Navitimer sapphire watch face: 手順 4、 3の画像 2 How to remove scratches from a Breitling Navitimer sapphire watch face: 手順 4、 3の画像 3
    • Start with level 6 diamond paste
    • You will apply about a dime size of paste, then using your finger to spread the paste evenly around the watch face.
    • After spreading out the diamond paste, turn your Dremel on its lowest speed and apply the felt tip to the watch face.
    • IMPORTANT: rotate the Dremel in circular motions as you work around the sapphire. DO NOT press to hard or Dremel too long on a specific area, it could crack your face.
    • Take little 20 second breaks allowing the face to cool down, if it over heats it could be many problems.
    • You will repeat the same steps above for each grade of diamond paste.
    • Apply a little more pressure on the really scratched area to get better results.
    • NOTE* when you press harder on specific areas using your Dremel make sure your not overheating the crystal, it can heat up in a matter of 5 seconds. Touch the area scratched often to ensure its cool.
  5. How to remove scratches from a Breitling Navitimer sapphire watch face: 手順 5、 3の画像 1 How to remove scratches from a Breitling Navitimer sapphire watch face: 手順 5、 3の画像 2 How to remove scratches from a Breitling Navitimer sapphire watch face: 手順 5、 3の画像 3
    • After removing the scratches from your watch face, then snap your bezel back on and re-attach your links.
    • Lastly, I used some car wax on my watch face to give it that gleem.
    • I HIGHLY HIGHLY recommend getting some cape cod cloths. They are AMAZING. Wipe down your wrist band with this and it will remove scratches and polish your watch.
    • The RESULT = PERFECTION!
    • Hope you enjoyed this tutorial. Notice the scratch on my Breitling is completely gone!
終わりに
3 の人々がこのガイドを完成させました。
Role
メンバー登録日: 2013年03月29日
544 ポイント
1ガイドが承認済み
4 件のコメント
Please keep in mind that this is a fake Breitling watch. Authentic Breitling watches have a different case construction and you will damage your watch if its authentic with this process.
rflood125 - 返信
nooooo! Don’t do that
fidji - 返信
DON’T DO THAT!! NEVER!
This chinese junk is a fake Breitling Navitimer, open it like this and you will destroy the bezel and the case. On a genuine one, bezel is screwed from inside, you have to open the case et unmount dial & movements to reach screws.
Keeping this post alive is a shame. I Just hope that breitling owners reading this poor "article" did'nt damaged their watch because of this :-(
fidji - 返信
Omg you @%^$$@$ , you should put how to fix FAKE navitimer , i almost destroyed mine .
Link Up - 返信
コメントを追加
統計データを表示:
過去 24時間: 4
過去 7 日: 25
過去 30 日: 103
今までの合計 28,501
