メインコンテンツにスキップ
How to remove and clean Arbor Rally Longboard bearings
必要な工具と部品
  1. How to remove and clean Arbor Rally Longboard bearings, How to remove and clean Arbor Rally Longboard bearings: 手順 1、 2の画像 1 How to remove and clean Arbor Rally Longboard bearings, How to remove and clean Arbor Rally Longboard bearings: 手順 1、 2の画像 2
    • Use the half inch wrench to remove the nut on each wheel. Then remove each wheel.
    • Be careful not to lose the washers that sit between the nut and wheel, they are small and hard to find after you lose them.
  2. How to remove and clean Arbor Rally Longboard bearings: 手順 2、 3の画像 1 How to remove and clean Arbor Rally Longboard bearings: 手順 2、 3の画像 2 How to remove and clean Arbor Rally Longboard bearings: 手順 2、 3の画像 3
    • Use needle nose pliers to remove the bearings from both sides of each wheel.
  3. How to remove and clean Arbor Rally Longboard bearings: 手順 3、 2の画像 1 How to remove and clean Arbor Rally Longboard bearings: 手順 3、 2の画像 2
    • Place the bearings in soapy water and let them soak for 5 minutes.
  4. How to remove and clean Arbor Rally Longboard bearings: 手順 4、 3の画像 1 How to remove and clean Arbor Rally Longboard bearings: 手順 4、 3の画像 2 How to remove and clean Arbor Rally Longboard bearings: 手順 4、 3の画像 3
    • Wipe off the dirt from each bearing and dry them thoroughly with a paper towel.
  5. How to remove and clean Arbor Rally Longboard bearings: 手順 5、 2の画像 1 How to remove and clean Arbor Rally Longboard bearings: 手順 5、 2の画像 2
    • Apply a few drops of lubricant to the inner portion on both sides of each bearing.
    • Spin the bearings and wipe off any extra lubricant that has not settled in.
  6. How to remove and clean Arbor Rally Longboard bearings: 手順 6、 3の画像 1 How to remove and clean Arbor Rally Longboard bearings: 手順 6、 3の画像 2 How to remove and clean Arbor Rally Longboard bearings: 手順 6、 3の画像 3
    • Push the bearing into the wheel by applying even pressure with your thumb.
  7. How to remove and clean Arbor Rally Longboard bearings: 手順 7、 3の画像 1 How to remove and clean Arbor Rally Longboard bearings: 手順 7、 3の画像 2 How to remove and clean Arbor Rally Longboard bearings: 手順 7、 3の画像 3
    • Spin the wheel to make sure that the bearings are properly aligned and running smoothly.
  8. How to remove and clean Arbor Rally Longboard bearings: 手順 8、 3の画像 1 How to remove and clean Arbor Rally Longboard bearings: 手順 8、 3の画像 2 How to remove and clean Arbor Rally Longboard bearings: 手順 8、 3の画像 3
    • Place the wheel on the axle followed by washer and then the nut.
    • Tighten the nut with your fingers as much as you can first and then use the wrench to finish the job.
    • Do not tighten the nut too much or else the wheel will not be able to spin. You should be able to slightly shake the wheel up and down along the axle.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Casey Barbello
メンバー登録日: 07/24/13
187 ポイント
1ガイドが承認済み
チーム
UC Santa Barbara, Team 1-6, Bradley Spring 2013 UC Santa Barbara, Team 1-6, Bradley Spring 2013人のメンバー
UCSB-BRADLEY-S13S1G6
5 メンバー
1のガイドは作成済み
2件のガイドコメント
Great guide! I was trying to figure out how to pop the bearings out - the needle nose pliers did a great job.
jewbot007 - 返信
It is usual practice to clean bearings with alcohol or a citrus cleaner; the latter is safer but more likely to leave residues. Since a citrus cleaning is water-based, you must quickly dry your bearings in order to prevent rust.
Mark Daniels - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 17
今までの合計 13,040
