メインコンテンツにスキップ
*Read guide note* How to rebuild a laptop CMOS battery
必要な工具と部品
  1. *Read guide note* How to rebuild a laptop CMOS battery, Determine what battery you need: 手順 1、 2の画像 1 *Read guide note* How to rebuild a laptop CMOS battery, Determine what battery you need: 手順 1、 2の画像 2
    • Most laptops use a CR2032 or 2025 cell. The CR2016 cell is uncommon.
    • Take the battery apart and check out what cell you need. This may be difficult depending on the wrap used.
  2. *Read guide note* How to rebuild a laptop CMOS battery, Disassemble the CMOS battery: 手順 2、 3の画像 1 *Read guide note* How to rebuild a laptop CMOS battery, Disassemble the CMOS battery: 手順 2、 3の画像 2 *Read guide note* How to rebuild a laptop CMOS battery, Disassemble the CMOS battery: 手順 2、 3の画像 3
    • If you break the leads, a new battery will need to be purchased.
    • After purchasing a battery, disassemble the CMOS battery. Use caution not to heavily bend the tabs. Too much damage may make them unusable.
    • Break the tabs off of the old battery. Dispose of based on your local laws.
  3. *Read guide note* How to rebuild a laptop CMOS battery, Verify polarity and tape the leads onto the new cell: 手順 3、 3の画像 1 *Read guide note* How to rebuild a laptop CMOS battery, Verify polarity and tape the leads onto the new cell: 手順 3、 3の画像 2 *Read guide note* How to rebuild a laptop CMOS battery, Verify polarity and tape the leads onto the new cell: 手順 3、 3の画像 3
    • ONLY USE ENOUGH TAPE FOR A FIRM HOLD. Using too much may short out the cell! In addition to using as little tape as possible, the cell must be tested before installation with a multimeter!
    • After the polarity has been matched, tape the positive lead to the new cell. To remove the risk of a failed rebuild, start on the + side and cut the tape to fit comfortably.
  4. *Read guide note* How to rebuild a laptop CMOS battery, Apply tape to the negative terminal: 手順 4、 1の画像 1
    • To place tape on the negative tab safely, try and keep the tape you cut as close as possible to the example image.
    • OFFSET the tape and terminal placement from the positive tab as much as possible.
    • After confirming the tape is not causing a short, add tape to the negative tab and tape down the negative terminal onto the new battery.
  5. *Read guide note* How to rebuild a laptop CMOS battery, Apply liquid electrical tape: 手順 5、 3の画像 1 *Read guide note* How to rebuild a laptop CMOS battery, Apply liquid electrical tape: 手順 5、 3の画像 2 *Read guide note* How to rebuild a laptop CMOS battery, Apply liquid electrical tape: 手順 5、 3の画像 3
    • Perfect coverage is not required. Focus on covering the major parts of the battery.
    • After verifying both leads are securely held onto the new cell, apply liquid electrical tape to the battery. 2-3 medium thickness coats are recommended.
終わりに
After building the replacement cell, install it in the notebook. Verify the battery works by setting the BIOS, powering it off and then removing the battery/AC adapter. If the CMOS memory is retained, your battery works.
7 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Nick
メンバー登録日: 11/10/09
88,851 ポイント
49のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,535のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 105
過去 30 日: 509
今までの合計 20,399
