メインコンテンツにスキップ
How to reboot the Flipper Zero
必要な工具と部品
    • Press the Back- and Left-buttons at the same time.
    • This is a hardware reboot that triggers the CPU to restart firmware. Even when the operating system does not respond, the hardware restart will still work.
    • In this mode, Flipper Zero activates the bootloader and is detected in the computer as a DFU device. When the firmware is updated, Flipper Zero enters the recovery mode on its own. To exit this mode, perform a reboot.
    • Release the Back-button but don't release the Left-button until the blue LED lights up.
    • If the bootloader is damaged, rebooting to update mode will not work. There will be no image on Flipper Zero's screen and the status LED will not work. In this case, only the full recovery mode will help to restore the device.
    • Disconnect Flipper Zero from USB.
    • Press and hold the OK- and Back-buttons for 30 seconds.
    • Connect the device to your computer.
    • Go to Main Menu > Settings > Power > Reboot.
    • Select Flipper OS, and then press the OK-button.
    • Connect your Flipper Zero to your PC.
    • Open Putty or a similar application.
    • Connect to the Flipper Zero COM port at 115200 bauds.
    • Enter the reboot-command and press Enter.
終わりに
Have fun!
6 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Sebastian
メンバー登録日: 08/19/18
31,049 ポイント
71のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 84
過去 30 日: 313
今までの合計 25,759
