はじめに
Kwikset key-in-knob locksets are one of the most readily available door locksets on the market. This guide will show you how to re-key (or re-pin) them yourself without needing to call a Locksmith.
Moreover, many of the techniques contained within this guide can be applied to other brands and door lock models as well!
必要な工具と部品
Start by removing the lockset from the door, or packaging. Separate and set aside the interior half of the lockset.
Hold the lock so that the side with the keyway is facing directly away from you.
Locate the driver bar on the back of the exterior, or keyed, half of the lockset. It is the long cylindrical post that protrudes from the back of the lock and is hollow on the end.
Insert the cylinder removal tool into the end of the driver bar and turn until the tab (circled red) is in the twelve 'o clock position.
Using the edge of the cylinder removal tool, depress the tab from step 2 while removing the driver bar.
Make sure the tab from step 1 is completely vertical and pointing towards one of the threaded cylinders. It can easily shift out of position, preventing removal of the driver bar.
Rotate the entire assembly 180 degrees so that the keyway faces the ceiling. While depressing the tab from step 2, wiggle the entire lockset. The driver bar should slide right out.
To rekey the cylinder, simply dump the bottom pins out of the plug and replace with the appropriate sized pins for the new key.
Ensure proper operation by reinserting the plug into the cylinder and rotating it to the 9 'o clock and 3 'o clock positions, taking care to make sure the plug does not accidentally come out of the cylinder.
13 の人々がこのガイドを完成させました。
6 件のコメント
Millions of Kwikset Smartkey Locks Vulnerable to Hacking, Say Researchers "Locks that are used in millions of homes and residential buildings worldwide and that are designed specifically to thwart hacking are easily opened with both a screwdriver and wire, two researchers say" what you recommend?
Wow, I had no idea it could be so easy! Re-keying a lock used to be so intimidating and seemed like it would take a long time and be expensive. But this looks like it makes it really simple and quick! Thanks so much for sharing, I'll have to try this!
I must say you have illuminate the complete process of Re-key. thanks for sharing this wonderful information.
Thanks for explaining these steps for Lock re key, I really appreciate your efforts and wish you luck for more amazing work in the future.
Confirmed this process works on Honeywell/Hyman Inc sold as Altas Home Security doorknobs at Menards and Lowes.
FlankSteak - 返信
