メインコンテンツにスキップ
How to re-caulk a bathroom sink
必要な工具と部品
  1. How to re-caulk a bathroom sink, Caulk seal: 手順 1、 1の画像 1
    • Clean and dry around the rim of the sink with a paper towel.
    • Make sure the old caulk is completely dry before moving on.
  2. How to re-caulk a bathroom sink: 手順 2、 1の画像 1
    • Remove the old caulk around the rim of the sink with a utility knife.
  3. How to re-caulk a bathroom sink: 手順 3、 1の画像 1
    • Remove any old caulk residue around the rim of the sink with a wet paper towel.
    • Then dry the area completely.
    • Ensure the area is completely clean and dry before applying the new caulk.
  4. How to re-caulk a bathroom sink: 手順 4、 3の画像 1 How to re-caulk a bathroom sink: 手順 4、 3の画像 2 How to re-caulk a bathroom sink: 手順 4、 3の画像 3
    • Apply painter's tape around the rim of the sink while leaving a small gap for caulk to be applied.
  5. How to re-caulk a bathroom sink: 手順 5、 2の画像 1 How to re-caulk a bathroom sink: 手順 5、 2の画像 2
    • Place the caulk tube into the gun.
    • Slowly press the trigger to release a thin line of caulk and move around the edge of the sink as you go.
  6. How to re-caulk a bathroom sink: 手順 6、 3の画像 1 How to re-caulk a bathroom sink: 手順 6、 3の画像 2 How to re-caulk a bathroom sink: 手順 6、 3の画像 3
    • Smooth out the caulk against the edge of the rim and counter with your wet index finger.
    • Keep a rag nearby to wipe excess caulk from your finger periodically.
    • Press against the caulk firmly while sliding your index finger as you go around the rim of the sink.
  7. How to re-caulk a bathroom sink: 手順 7、 3の画像 1 How to re-caulk a bathroom sink: 手順 7、 3の画像 2 How to re-caulk a bathroom sink: 手順 7、 3の画像 3
    • Pull the tape away from the counter immediately after applying the caulk.
    • Pulling away from the counter will help keep the caulk in a straight line.
  8. How to re-caulk a bathroom sink: 手順 8、 1の画像 1
    • Wipe off any excess caulk from the edge of the rim with a wet paper towel.
  9. How to re-caulk a bathroom sink: 手順 9、 1の画像 1
    • Let the new caulk dry for at least a day before using the sink.
ゴール
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Thi Nguyen
メンバー登録日: 04/29/20
201 ポイント
1ガイドが承認済み
チーム
UW Tacoma, Team S1-G43, Cardinal Spring 2020 UW Tacoma, Team S1-G43, Cardinal Spring 2020人のメンバー
UWT-CARDINAL-S20S1G43
1 メンバー
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 36
過去 30 日: 140
今までの合計 7,137
