メインコンテンツにスキップ
How to perform a Hard Reset on the Nintendo DS Lite
必要な工具と部品
  1. How to perform a Hard Reset on the Nintendo DS Lite, Battery: 手順 1、 1の画像 1
    • Turn the DS to the back side.
  2. How to perform a Hard Reset on the Nintendo DS Lite: 手順 2、 2の画像 1 How to perform a Hard Reset on the Nintendo DS Lite: 手順 2、 2の画像 2
    • This is the PH00 Screw,
    • Unscrew it.
    • The screw remains captive to the battery cover, you do not need to worry about losing it.
  3. How to perform a Hard Reset on the Nintendo DS Lite, Removing the cover: 手順 3、 2の画像 1 How to perform a Hard Reset on the Nintendo DS Lite, Removing the cover: 手順 3、 2の画像 2
    • Remove the battery cover.
  4. How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: 手順 4、 3の画像 1 How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: 手順 4、 3の画像 2 How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: 手順 4、 3の画像 3
    • Wedge the edge on the side of the battery using a spudger.
  5. How to perform a Hard Reset on the Nintendo DS Lite, .: 手順 5、 1の画像 1
    • Take out the battery and leave it for at least 15-30 seconds.
  6. How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: 手順 6、 3の画像 1 How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: 手順 6、 3の画像 2 How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: 手順 6、 3の画像 3
    • Reinsert the battery.
    • Make sure the battery matches the + and the - connectors.
  7. How to perform a Hard Reset on the Nintendo DS Lite, Screwing in the cover: 手順 7、 2の画像 1 How to perform a Hard Reset on the Nintendo DS Lite, Screwing in the cover: 手順 7、 2の画像 2
    • Put the cover back on and screw it in.
  8. How to perform a Hard Reset on the Nintendo DS Lite, Finish: 手順 8、 1の画像 1
    • If everything done correctly, You should be at the setup screen, It would look like when you got the ds from the store.
    • You can hold A + B + X + Y + R while turning on the system and the ds will boot into a ds cartridge without doing setup, you can boot the Game Pak/GBA Cartridge if you hold A + B + X + Y + L Instead.
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Artem Ivat
メンバー登録日: 02/05/20
2,631 ポイント
12のガイドは作成済み
チーム
Kid fixers Kid fixers人のメンバー
Community
149 メンバー
283のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 75
過去 30 日: 394
今までの合計 7,230
