この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
For any internal work on the N9, you'll need to open up the device. This guide will show just that part.
必要な工具と部品
Click open the USB input protector lid and pull it from the housing.
Also remove the SIM card holder.
Remove screws from the top.
Press your screwdriver against the backside of the white pieces of plastic, and the screen will click out at the top side of the phone.
Using a plastic tool, carefully open up the distance between the screen and the housing until the screen is only attached with 2 cables.
With the same plastic tool, disconnect the screen cables still attached to the phone.
The screen is now separated from the rest of the phone.
ある他の人がこのガイドを完成しました。
