メインコンテンツにスキップ
How to make Dyson AM07 (more) useable!
必要な工具と部品
  1. How to make Dyson AM07 (more) useable!, Overview and button names: 手順 1、 1の画像 1
  2. How to make Dyson AM07 (more) useable!, Add some dots!: 手順 2、 2の画像 1 How to make Dyson AM07 (more) useable!, Add some dots!: 手順 2、 2の画像 2
    • Plug in your glue gun and let it heat up.
    • I made a big dot on the oscillation button, another one on the Standby ON/OFF button, and two more dots (big and small) on the Airflow control buttons. I don't use the Sleep Timer so I haven't added any dots to those two buttons.
    • If you don't get it right on the first try, don't worry. Just wait a couple of seconds for the glue to cool down and remove the dot. The glue comes off without leaving any residue or marks on the plastic.
  3. How to make Dyson AM07 (more) useable!, Bonus points: make shapes: 手順 3、 2の画像 1 How to make Dyson AM07 (more) useable!, Bonus points: make shapes: 手順 3、 2の画像 2
    • I used a carpet cutter (sharpest knife I had lying around) to cut the dot on the Standby ON/OFF button into an "I" shape for a little bit of different tactile feedback.
    • Some more ideas for customization: while the glue is still fluid, stick little parts of plastic, for example, in it to get different kind of buttons.
  4. How to make Dyson AM07 (more) useable!, The result: 手順 4、 3の画像 1 How to make Dyson AM07 (more) useable!, The result: 手順 4、 3の画像 2 How to make Dyson AM07 (more) useable!, The result: 手順 4、 3の画像 3
    • They could look better but the buttons are a lot more useable now, in my opinion.
終わりに
To undo these changes and restore your remote, just peel off the dots.
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Frank
メンバー登録日: 06/08/15
85 ポイント
1ガイドが承認済み
4 件のコメント
I would not recommend this. I would just order custom buttons and use some 3m tape to attach to the remote. Also, I don't have any problems finding the right buttons in the dark to control my fan.
kayshawncartel - 返信
Good for you. Then just ignore this guide.
Frank -
Bit a crap mod me thinks… not well thought out… its pretty obvious that if you do this the control will no longer sit nicely on top of the fan! Better off learning your left from your right ;-)
Abdullah Khan - 返信
Useful, but not sure about the appearance.
I’m interested in how to alter a Dyson Hot & Cold fan bought in the UK for use in the US…if anyone has recommendations?
James Bowkett - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 24
過去 30 日: 83
今までの合計 12,766
