メインコンテンツにスキップ
How to jump start a 2010 Honda Insight
必要な工具と部品
  1. How to jump start a 2010 Honda Insight, How to jump start a 2010 Honda Insight: 手順 1、 1の画像 1
    • Make sure that both cars are turned off.
    • Pop open the hood of the Insight by pulling the lever located here:
  2. How to jump start a 2010 Honda Insight: 手順 2、 1の画像 1
    • Open the hood by reaching under the hood (in the front and center) and pulling the lever.
  3. How to jump start a 2010 Honda Insight: 手順 3、 1の画像 1
    • Lock open the hood by grabbing the rod and inserting it into the hole on the under side of the hood.
  4. How to jump start a 2010 Honda Insight: 手順 4、 1の画像 1
    • Open the hood of the secondary car, and lock it up into place (with spring-action rod if necessary).
  5. How to jump start a 2010 Honda Insight: 手順 5、 1の画像 1
    • Grab your jumper cables.
  6. How to jump start a 2010 Honda Insight: 手順 6、 1の画像 1
    • Locate the battery in both the Honda Insight and the secondary car.
    • The battery always has a big red plastic part that will indicate the positive terminal.
  7. How to jump start a 2010 Honda Insight: 手順 7、 1の画像 1
    • WARNING! DO NOT LET THE LEADS TOUCH EACH OTHER OR ANY OTHER METAL!
    • Attach the RED lead to the secondary car's battery where the positive (RED) terminal is.
  8. How to jump start a 2010 Honda Insight: 手順 8、 1の画像 1
    • Attach the other RED lead to the positive (RED) terminal of the Honda Insight's battery.
  9. How to jump start a 2010 Honda Insight: 手順 9、 1の画像 1
    • Attach the BLACK lead to the secondary car's battery where the negative terminal is.
  10. How to jump start a 2010 Honda Insight: 手順 10、 3の画像 1 How to jump start a 2010 Honda Insight: 手順 10、 3の画像 2 How to jump start a 2010 Honda Insight: 手順 10、 3の画像 3
    • Attach the other BLACK lead to the grounding strap located here:
    • Do not connect the black lead to any other part of the car.
  11. How to jump start a 2010 Honda Insight: 手順 11、 1の画像 1
    • Start the engine of the secondary car and let the engine run for 1-2 minutes.
  12. How to jump start a 2010 Honda Insight: 手順 12、 1の画像 1
    • Start the engine of the Honda Insight and let it run for 2-3 minutes.
    • NOTE: If your Insight does not start at this point, let the battery charge for a few more minutes.
  13. How to jump start a 2010 Honda Insight: 手順 13、 1の画像 1
    • After the Insight has successfully started and has been running for a few minutes, remove leads in reverse order of attachment.
    • WARNING: DO NOT LET THE LEADS TOUCH EACH OTHER OR ANY OTHER METAL!
    • It may appear in this photo that the battery cables are incorrectly hooked up to battery terminals on both vehicles. Make sure to follow the earlier instructions regarding using the grounding strap on the Insight instead.
  14. How to jump start a 2010 Honda Insight: 手順 14、 1の画像 1
    • Drive the Insight for at least 30 minutes before turning it off again to ensure a full charge of your battery.
    • NOTE: You may also simply let the engine run for 30 minutes rather than driving.
終わりに
If your car still does not run after all of this, call a mechanic because you may have a bigger problem than a dead battery.
2 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Hannah Jackson
メンバー登録日: 02/23/15
138 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 12-4, Green Winter 2015 Cal Poly, Team 12-4, Green Winter 2015人のメンバー
CPSU-GREEN-W15S12G4
5 メンバー
9のガイドは作成済み
2 件のコメント
Where should you clamp the black lead if using a portable jump starter and cable won't reach the grounding strap? Thanks!
missyunc - 返信
When I start the engine, the alarm is going on. How to turn it off?
Eugenia Grosu - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 22
過去 30 日: 127
今までの合計 21,632
