メインコンテンツにスキップ
はじめに
Is your disco ball making screechy noises instead of groovy beams? You probably need to grease up the gear to make that noise go away and bring back the jams. This guide will teach you how to get to the gear so you can grease it up and get back to partying!
パーツ
パーツは指定されていません。
  1. Turn the device over so that the base is on top.
    • Turn the device over so that the base is on top.
  2. Peel off the piece of metal that is glued to hold the two halves of the base together.
    • Peel off the piece of metal that is glued to hold the two halves of the base together.
    • You may need rubber cement to reapply the piece of metal when reassembling the device.
  3. Unscrew the four 10mm Phillips head screws on the bottom of the device. Once the base is removed, the device should look as shown on the picture.
    • Unscrew the four 10mm Phillips head screws on the bottom of the device.
    • Once the base is removed, the device should look as shown on the picture.
  4. Skip the upgrade.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
    Skip the upgrade.
    SKIPANDSAVE10
    Save Now
  5. Use a pair of tweezers to crush the sides of the wirenuts. The wirenuts are crimped to lock the wires in place. Usually the wires are just twisted into them.
    • Use a pair of tweezers to crush the sides of the wirenuts.
    • The wirenuts are crimped to lock the wires in place. Usually the wires are just twisted into them.
    • Pull all of the wires out of the wirenuts.
  6. Separate the wires that belong to the motor. The wires should be small and black.
    • Separate the wires that belong to the motor.
    • The wires should be small and black.
    • Remove the motor.
  7. Unscrew the two 10 mm philips head screws.
    • Unscrew the two 10 mm philips head screws.
    • Unscrew the center 14 mm philips head screw.
    • Remove the plastic piece stabilizing the gear.
  8. Apply oil to the gear directly from the oil bottle or with a Q-tip.
    • Apply oil to the gear directly from the oil bottle or with a Q-tip.
まとめ
Nick Kaprielian
メンバー登録日: 2014年01月14日
495 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 17-3, Forte Winter 2014 Cal Poly, Team 17-3, Forte Winter 2014人のメンバー
CPSU-FORTE-W14S17G3
5 メンバー
7のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 5
今までの合計 572
