必要な工具と部品
Requirements:
A internet conection
A charged A1000
A usb data cable
And most importantly a windows pc
And translate the page. It should be like this <--
Find your model number on the list of firmware and download it.
Download the flash tool http://lenovo-forums.ru/Files/OS/Tablets...
And the usb driver http://lenovo-forums.ru/Files/OS/A390/MT...
Unzip the firmware and the flashtool in any folder only with latin characters.
open Flash_tool.exe. and select File > Open Scatter-loading file ... and select the file MT6577_Android_scatter_emmc.txt from the firmware folder
Check the box DA DL All With Check Sum and Press the Firmware -> Upgrade button
If this <-- happens check the firmware and delete checksum.ini from the firmware and try again
Plug in your tablet turned off
First wait if you get a green circle after flashing you have a successfully flashed tablet.
Congratulations you have a working tablet
ある他の人がこのガイドを完成しました。
