はじめに
We all love our small and crazy fast MacBook Pro machines
But sometimes we can spill some drinks on the KB and even it is not a big amount of liquid and our reaction was fast some keys from the KB can start to make strange cracking sounds and to stuck when they are used
Make a note of what keys need to repair
Better lock your Mac to the password screen
To remove the key from the mechanism insert the plastic tool to the bottom right and left side and gently pull up until you feel and hear a clicking sound
After that pull the card to the upper side of the key and move the key down. The key should be removed
This is how the plastic mechanism looks like
This part is the main part that is responsible for the problems
To remove this part for cleaning unpin the two small plastic pins to the bottom right and left with small screwdriver for example and then move the part up to remove
You need just a small plastic bottle with water ONLY !
Collect all keys and mechanisms and put them into the bottle with water
Shake them / change the water / shake them again
Take them out on paper to dry
How the cleaned mechanism should look like
Well... the spacebar key is a little bit tricky
To remove the key the way is the same - push the plastic card to the bottom and pull until unclip
Then move the key up and remove the key
Be careful because the key is with 2 metal scobes attached too
You need to unpin from the metal socket too
Under the spacebar key, there are 2 plastic mechanisms
They are a little bit different
To remove the same are left, down and right keyses
The UP key is opposite
To remove the arrow keys - left, down, and right you need to push and pull up from the left side and then to unclip the key from the right side
The UP key is the same but he is the opposite so this means to do the same but first to pull up from the right side and then to unclip from the left side
First, ensure that mechanisms and keys are dry
Mount the mechanisms in reverse
Insert them first to the bottom and then gently clip the little plastic parts
Mount the key - slide the key from the bottom to the top and then gently press the left and right sides of the key to clip the key to the mechanism
When the mechanisms and keys are ready insert the mechanisms first to clip the small metal scobe and then clip the two small plastic pins
This is how key and mechanism looks like - pic2
Here you need to help with one hand to up the mechanism with a screwdriver for example and with your other hand to mount the left side of the key
After that just need to clip the right side
The UP key ONLY is opposite
ある他の人がこのガイドを完成しました。
