メインコンテンツにスキップ
How to fix sticky buttons for a TI-30X IIS
必要な工具と部品
  1. How to fix sticky buttons for a TI-30X IIS, How to fix sticky buttons for a TI-30X IIS: 手順 1、 1の画像 1
    • Use the #0 Phillips screwdriver to remove the 4 screws at the back of the calculator
  2. How to fix sticky buttons for a TI-30X IIS: 手順 2、 2の画像 1 How to fix sticky buttons for a TI-30X IIS: 手順 2、 2の画像 2
    • Use a Flat Head Screwdriver or a thin strong object like a card to separate the front and the back of the case.
    • Separate it carefully to not break the 8 clips.
  3. How to fix sticky buttons for a TI-30X IIS: 手順 3、 1の画像 1
    • Use a pointed tool to push the battery out of its terminal until it is out far enough to remove with your fingers.
  4. How to fix sticky buttons for a TI-30X IIS: 手順 4、 2の画像 1 How to fix sticky buttons for a TI-30X IIS: 手順 4、 2の画像 2
    • Using a knife, Razor, or other perscion cuting tool, remove the top of the 10 plastic rivets that connect the keyboard sensor to the front case.
    • Be careful when moving the calculator when the rivets are gone since they keep the calculator's keyboard sensor and keys together when the calculator back case is off. Keep keys down to prevent the loss of keys.
  5. How to fix sticky buttons for a TI-30X IIS: 手順 5、 2の画像 1 How to fix sticky buttons for a TI-30X IIS: 手順 5、 2の画像 2
    • Use a flat tool to unclip the two tabs that secure the circuit board.
  6. How to fix sticky buttons for a TI-30X IIS: 手順 6、 1の画像 1
    • Remove the circuit board, keyboard sensor, and keyboard membrane from the front case.
    • The circuit board has 2 wires connecting to the solar panel, This cannot be removed without soldering/desoldering the connecting wires. Move all listed parts above to a location where there is little to no tension on the wired to prevent damage.
  7. How to fix sticky buttons for a TI-30X IIS: 手順 7、 2の画像 1 How to fix sticky buttons for a TI-30X IIS: 手順 7、 2の画像 2
    • Use rubbing alcohol to wipe down both parts using q-tips or any other cleaning cloth.
  8. How to fix sticky buttons for a TI-30X IIS: 手順 8、 2の画像 1 How to fix sticky buttons for a TI-30X IIS: 手順 8、 2の画像 2
    • Using q-tips, remove the keys and clean the keyhole and the keys to ensuring that they are residue-free. When done, return all the keys to their original position.
    • Keys are very light and small, have a container or a safe location to keep keys to prevent keys from getting lost.
終わりに
作成者
1人の作成者と共同作成されました。
Yong Ho Kim
メンバー登録日: 01/31/23
166 ポイント
1ガイドが承認済み
チーム
York University, Team P-9, Allen Winter 2023 York University, Team P-9, Allen Winter 2023人のメンバー
YORK-ALLEN-W23SPG9
1 メンバー
1のガイドは作成済み
コメント 1 件
Fantastic guide. Is there any concern with cutting the plastic rivets?
dfen - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 54
今までの合計 203
