はじめに
This easy hack will save you from buying a new mouse if your scroll wheel is acting up and is not functioning properly causing you a terrible scrolling experience.
The cause of this issue is, the inner plate holding the rotating mechanism has become loose due to wear and time
必要な工具と部品
Flip the mouse upside down and remove the screw on the bottom of the mouse casing using a screwdriver
Slowly remove the metallic clamps from the plastic body to free the plastic case, holding the rotating mechanism .(If possible remover the metallic case fully from underneath the board, if it is not soldered)
Pull back or bend the plastic case a little bit for easy insertion of spring
Place a small coil spring on the extreme end of the small metallic plate holding the rotating mechanism against the plastic body
Pull the other end of the coil and place it on the other end where the scroll wheel is inserted
This will ensure that the small metallic plate and rotating mechanism are not loose thereby not causing a jumpy scroll wheel
5 の人々がこのガイドを完成させました。
3件のガイドコメント
Ottima guida come sempre! Complimenti
Excellent et si la souris est hors de cause penser à éteindre et rallumer le PC.
