メインコンテンツにスキップ
How to fix iPhone 6S/6S+ home button, when home button click does not work.
必要な工具と部品
  1. How to fix iPhone 6S/6S+ home button, when home button click does not work., Home Button Assembly: 手順 1、 1の画像 1
    • Remove the two 1.9 mm Phillips screws securing the home button bracket.
  2. How to fix iPhone 6S/6S+ home button, when home button click does not work.: 手順 2、 2の画像 1 How to fix iPhone 6S/6S+ home button, when home button click does not work.: 手順 2、 2の画像 2
    • Remove the home button bracket.
  3. How to fix iPhone 6S/6S+ home button, when home button click does not work.: 手順 3、 2の画像 1 How to fix iPhone 6S/6S+ home button, when home button click does not work.: 手順 3、 2の画像 2
    • Use the pointed tip of a spudger to disconnect the home button cable from its connector on the display assembly.
  4. How to fix iPhone 6S/6S+ home button, when home button click does not work.: 手順 4、 2の画像 1 How to fix iPhone 6S/6S+ home button, when home button click does not work.: 手順 4、 2の画像 2
    この手順で使用する道具:
    iOpener
    $19.99
    購入する
    • The rubber gasket surrounding the home button is very thin and tears easily.
    • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
    • Using your fingertip, gently press up on the home button from the front side of the display assembly. Use firm, constant pressure to slowly separate the home button's rubber gasket from the front panel.
  5. How to fix iPhone 6S/6S+ home button, when home button click does not work.: 手順 5、 3の画像 1 How to fix iPhone 6S/6S+ home button, when home button click does not work.: 手順 5、 3の画像 2 How to fix iPhone 6S/6S+ home button, when home button click does not work.: 手順 5、 3の画像 3
    • Use the pointed end of a spudger to pry the lightly-adhered home button flex cable off the display assembly.
  6. How to fix iPhone 6S/6S+ home button, when home button click does not work.: 手順 6、 2の画像 1 How to fix iPhone 6S/6S+ home button, when home button click does not work.: 手順 6、 2の画像 2
    • Remove the home button assembly.
  7. How to fix iPhone 6S/6S+ home button, when home button click does not work., Finding the Cause: 手順 7、 3の画像 1 How to fix iPhone 6S/6S+ home button, when home button click does not work., Finding the Cause: 手順 7、 3の画像 2 How to fix iPhone 6S/6S+ home button, when home button click does not work., Finding the Cause: 手順 7、 3の画像 3
    • Though this step isn't necessary, here are some images to help you see the cause of the issue
    • Here you can see the micro-tear that happens just under the edge of the home button.
  8. How to fix iPhone 6S/6S+ home button, when home button click does not work., Locating the Component: 手順 8、 3の画像 1 How to fix iPhone 6S/6S+ home button, when home button click does not work., Locating the Component: 手順 8、 3の画像 2 How to fix iPhone 6S/6S+ home button, when home button click does not work., Locating the Component: 手順 8、 3の画像 3
    • Find the resistor tied to the home button and remove the protective layer around that resistor.
  9. How to fix iPhone 6S/6S+ home button, when home button click does not work., Verify the Issue: 手順 9、 1の画像 1
    • Test continuity between top part of the resistor and the home button.
    • If you get constant continuity between these two points, you have another issue and this process will not fix your issue.
  10. How to fix iPhone 6S/6S+ home button, when home button click does not work., Soldering (Part 1): 手順 10、 1の画像 1
    • Now that you have confirmed the issue, you can fix it by running an external trace between the two components you just tested.
    • Solder your wire to the physical part of the home button first.
  11. How to fix iPhone 6S/6S+ home button, when home button click does not work., Soldering (Part 2): 手順 11、 3の画像 1 How to fix iPhone 6S/6S+ home button, when home button click does not work., Soldering (Part 2): 手順 11、 3の画像 2 How to fix iPhone 6S/6S+ home button, when home button click does not work., Soldering (Part 2): 手順 11、 3の画像 3
    • Guide the wire to the second component
    • It is easier to keep the wire in place if you cut part of the glue out in a line. That way you can insert the wire into the cutout to prevent it from moving
    • Add some glue or UV resin to keep the wire in place.
    • Solder the wire to the top end of the component.
  12. How to fix iPhone 6S/6S+ home button, when home button click does not work., Glue and Assemble: 手順 12、 1の画像 1
    • Add some UV Curing Glue to the solder points.
    • To be safe, you can place some Kapton tape over the top of the new trace to keep it from moving. Be careful as this new trace is fragile where it isn't glued.
    • Follow steps 1-6 in reverse order to re-assemble the device.
終わりに
After testing the home button and confirming that the repair worked, you can re-assemble your device.
11 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Jon
メンバー登録日: 08/17/18
633 ポイント
1ガイドが承認済み
4 件のコメント
Superb it worked
kumkrish36 - 返信
Looks like have to attempt this. Have done fairly fine soldering before but maybe nothing this small. What size jumper to use? 0.1mm or 0.02mm?
Howard - 返信
Thanks Howard. Sorry I haven’t been around for a while. The wire I used was 0.02 mm. You would probably be fine with a thicker wire, this is just what I have on hand.
Jon -
Great tutorial. There is a diagram floating around on the web that has the polarity reversed. I did that first and didn’t work before finding this guide and corrected the wiring. Works great now.
Besides a good fine tip soldering iron and at least magnifying goggles, really good flux makes all the difference on this job since everything is so small. I had some clear liquidy flux (Kester 951? don’t recall, bought long ago to help reflow GPU+SOC BGAs) That worked great as heat instantly flowed to all the right places. Necessary with tiny solder points and rework wire.
Howard - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 43
過去 30 日: 159
今までの合計 10,021
