メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Does your door sound noisy and rattly when closing, like this? Here's how to fix it!
ビデオの概要
  1. The door card is held securely in place with 5 screws.
    • The door card is held securely in place with 5 screws.
    • Keep in mind the door card has up to 3 wire bundles attached to it. Be careful when removing it! Be prepared to support it while dealing with the wires.
  2. Using a spudger, work off the cap of the first screw. The cap is tight; you may need a jimmy or metal spudger. Using the flat end of a spudger, remove the airbag emblem. The emblem has clips on the top and bottom -- work carefully.
    • Using a spudger, work off the cap of the first screw. The cap is tight; you may need a jimmy or metal spudger.
    • Using the flat end of a spudger, remove the airbag emblem. The emblem has clips on the top and bottom -- work carefully.
  3. Using a T20 Torx driver with extension, remove all 5 bolts.
    • Using a T20 Torx driver with extension, remove all 5 bolts.
  4. If you're working on the driver side door, remove the mirror control module. Disconnect it from its wiring plug.
    • If you're working on the driver side door, remove the mirror control module. Disconnect it from its wiring plug.
  5. 今あるものを使い続けましょう
    オールインワインキットで安く修理して、節約しましょう。
    iPhone 修理キットを見る
    今あるものを使い続けましょう
    iPhone 修理キットを見る
  6. Using a trim tool or similar, begin at the bottom of the door card and pop the card away from the door frame. After you've released the bottom clips, work your way around.
    • Using a trim tool or similar, begin at the bottom of the door card and pop the card away from the door frame.
    • After you've released the bottom clips, work your way around.
    • You will need to lift the door card from the door frame in order to fully release it. Be careful!
    • Disconnect the following from the door panel:
    • Unlocking cable
    • Speaker cable(s)
    • Set the door panel aside.
  7. The door panel is now removed.
    • The door panel is now removed.
    • You will see the airbag module, vapor barrier, and other components.
  8. Very gently, peel back the vapor barrier to expose the retaining bolt. Roll the window up.
    • Very gently, peel back the vapor barrier to expose the retaining bolt.
    • Roll the window up.
    • The tar-like substance used to seal the vapor barrier to the door frame WILL release itself to a gentle pull, but it is EXTREMELY sticky, and too much pulling will tear your barrier. Slow and steady is the name of the game!
    • Inspect the bolt. It is probably missing a nut!
  9. While you're in here, inspect and tighten the bottom bolt.
    • While you're in here, inspect and tighten the bottom bolt.
  10. Look in the bottom of your door and locate the nut that fell off that top bolt.
    • Look in the bottom of your door and locate the nut that fell off that top bolt.
    • Replace the nut onto the upper bolt and tighten.
    • In a pinch, you can use a little bit of that tarry substance to temporarily paste the nut to your fingertip in order to screw it on to the bolt.
    • Ta da! Now closing the door sounds great!
終わりに
To reassemble your door, follow these instructions in reverse order.
ある他の人がこのガイドを完成しました。
Dom Santangelo
メンバー登録日: 2016年09月19日
523 ポイント
3のガイドは作成済み
コメント1件
What is this bullshit? Ever think people may have both bolts there and tightened down still? Ever think other ifixit $@$* may still need to occur? And this is all you have to offer? Awesome thoroughness…
spamaccount420 - 返信
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 75
今までの合計 5,459
