メインコンテンツにスキップ
How to fix a break in a Belkin Lightning Charger Cable
必要な工具と部品
  1. How to fix a break in a Belkin Lightning Charger Cable, How to fix a break in a Belkin Lightning Charger Cable: 手順 1、 1の画像 1
    • Unplug the charger before starting with the repair.
    • Locate the damaged area on the charger.
  2. How to fix a break in a Belkin Lightning Charger Cable, Cut out the broken section: 手順 2、 1の画像 1
    この手順で使用する道具:
    Flush Cutter
    $29.99
    • Cut out the part where the wire is broken using a pair of wire cutters.
  3. How to fix a break in a Belkin Lightning Charger Cable, Strip the cable: 手順 3、 1の画像 1
    この手順で使用する道具:
    Flush Cutter
    $29.99
    • Strip off about 3cm of the black insulation with the wire strippers to expose the red and black wire on both parts of the cable.
    • You can use your flush cutters or a knife as an improvised wire stripper by cutting just enough so that you don't damage the small wires inside and pulling the insulation off.
    • Be safe when using the flush cutters or a knife: Pull away from your face and body when stripping wires.
  4. How to fix a break in a Belkin Lightning Charger Cable, Add Heat-shrink tubing: 手順 4、 1の画像 1
    • Slide about 1.75 of Heat-shrink tubing on a black and red wire each.
    • Slide about 5cm of Heat-shrink tubing on a charger cable.
  5. How to fix a break in a Belkin Lightning Charger Cable, Strip the wires: 手順 5、 2の画像 1 How to fix a break in a Belkin Lightning Charger Cable, Strip the wires: 手順 5、 2の画像 2
    この手順で使用する道具:
    Flush Cutter
    $29.99
    • Strip off about 1cm of the insulation of each of the wires with the wire strippers.
    • You can use your flush cutters as an improvised wire stripper by cutting just enough so that you don't damage the copper strands inside and pulling the insulation off.
    • Wires are fragile, so when stripping be sure not to snip the wires.
  6. How to fix a break in a Belkin Lightning Charger Cable, Twist the wires together: 手順 6、 1の画像 1
    • Twist together the corresponding wires.
    • Be sure all wiring is bonded together.
    • Move the small heat shrinking tubes up to cover the exposed parts of the wires.
  7. この手順で使用する道具:
    Heat Gun
    $24.99
    • Evenly heat the tubing with a heat gun. Make sure the tube is properly shrinking.
    • The tubing gets hot—hold the cord at the end of each side.
  8. How to fix a break in a Belkin Lightning Charger Cable, Move the Heat-shrink tubing up: 手順 9、 1の画像 1
    • Move the large heat shrinking tube up to cover the wires.
  9. How to fix a break in a Belkin Lightning Charger Cable, Heat the Heat-shrink tubing: 手順 10、 1の画像 1
    この手順で使用する道具:
    Heat Gun
    $24.99
終わりに
Happy fixing!
作成者
3人の作成者と共同で作成されました。
Marcus Watson
メンバー登録日: 04/11/19
157 ポイント
1ガイドが承認済み
チーム
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 31
今までの合計 1,433
