If you found any loose screws on the door hinge, use your screwdriver to tighten them.
To make this easier, you can slightly lift your door while screwing the screws.
This is your strike plate. Take a look to see if it has shifted, and in what direction it shifted.
In the photo provided you can tell my plate has been shifted downwards.
Using the wood chisel, chisel out the wood above the line to make space for the new placement of the strike plate.
An easy way to do this is to tap the end of the chisel with a hammer.
Place the toothpicks into the openings. By doing this, you are preventing your new screws from falling back into the old spot causing the door to be re-positioned again.
Let the toothpicks sit for about 10 minutes
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
