はじめに
I can't find any tutorial on fixing Stratus Duo, So I decided to make one myself.
So my controller had fallen to the ground, and the R2 trigger ceased working.
I found that a cute little magnet triggers it, and it had fallen off from its encasement.
It's as easy as putting the magnet back.
The only tricky part is the disassembling.
必要な工具と部品
A screwdriver with...
a Y 2.0 sized Tri-wing screwhead for the case
and Phillips head for the motherboard.
Some kind of pry (Prolly your nail 🤣, or your broke-ass credit card might do 💵)
Pair of tweezers for delicate tasks
Pair of dry, steady hands. (No caffeine for you!)
There are 5 screws in the case, one of them is under the sticker (Circled in red)
Pry open from the bottom (Red line) . don't pry from the top (orange line), otherwise, the fastening slot will be damaged. (photo showed in next step)
The weight (yellow) is not fixed and can easily drop. Don't lose them.
There's a non-functional plastic plug (green circle) that'll fall easily too. Be careful.
You will find 2 connections. (red circle)
The white strip is the data line. To disconnect, use a tweezer to (1) slide open the black button from both sides , then (2) pull the blue part.
The tri-colored wire is the power line. Simply pull it up. (Don't forget it's orientation)
Seperate the upper and lower controller case
Your magnet won't rattle because it's attached somewhere else inside your controller.
Find the bastard and pick it up with tweezers
In this step, you may attempt to stick it back to the black encasement. But if you fail so, continue to the next step.
Unscrew the 6 screws,
Separate the lower analog motherboard first. Beware of the connection (Yellow)
And then seperate the upper motherboard.
Unscrew these 2 screws (red circle) to detach the trigger button. (From behind, duh!) (P.S. I was lazy and I didn't take photos of the disassembled button and motherboard 😶)
You should have good access here. Now yell "GET BACK INTO THE F**KING MACHINE!!! MAGNET!!!" (If you know the reference😏)
Reassemble it like lego.
Reconnect the cables and try out the buttons with some controller testing site before screwing it back in
Did I save the day for you? If yes, have a great day! If not, maybe you missed some steps. ¯\_(ツ)_/¯
当重新组装你的设备时,请按照说明的相反顺序进行操作。
ある他の人がこのガイドを完成しました。
