メインコンテンツにスキップ
How to fix Logitech Anywhere MX Phantom Double Click
必要な工具と部品
  1. How to fix Logitech Anywhere MX Phantom Double Click, Front Screw Removal: 手順 1、 1の画像 1
    • The front screws are underneath the front gliders. The can be removed with a butterknive or Plastic Opening Tool. The gliders have three layers, be careful not to seperate them.
  2. How to fix Logitech Anywhere MX Phantom Double Click, Removing Back Screws: 手順 2、 1の画像 1
    • The back screws are underneath the stickers with the battery images. You can either remove them, like I did, or just poke a hole into them to get to the screws.
  3. How to fix Logitech Anywhere MX Phantom Double Click, Identification of the Problem: 手順 3、 1の画像 1
    • After the four screws are removed, the top and the bottom part can be easily taken apart. In the top part the grove that was made by the click-sensor should be cleary visible. This causes the phantom double clicks.
  4. How to fix Logitech Anywhere MX Phantom Double Click, Solution of the Problem: 手順 4、 1の画像 1
    • Put a piece of tape over the groove.
終わりに
63 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Stefan Magometschnigg
メンバー登録日: 11/26/16
1,957 ポイント
2のガイドは作成済み
43件のガイドコメント
Worked well for me, lets see how long it'll last.
Wynadorn - 返信
Worked for me too...saved a great little mouse!
jcrhino - 返信
Thank you for this hint! It worked perfectly
Wojciech Gradkowski - 返信
Thank you, it worked!
Jakab Ponoczky - 返信
Thank you for this guide! Got my mouse working and saved me some money :)
Kon-Kon Chao - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 49
過去 30 日: 327
今までの合計 50,514
