必要な工具と部品
Device is running slow: -First, close all running applications that may be using disk space -Then restart the computer to refresh programs and applications.
-If this doesn’t work, you need to make sure that there is at least 15% space open on the hard drive To check this, open up the “Computer” from the start menu. This should display your hard drive memory. If you have less than 15% space, delete unused items to free up space. This will speed up your computer significantly
もう少しです!
終わりに
