メインコンテンツにスキップ
How to fix squeaking on the GEN 2 Wheelchair
必要な工具と部品
  1. How to fix squeaking on the GEN 2 Wheelchair, How to fix squeaking on the GEN 2 Wheelchair: 手順 1、 3の画像 1 How to fix squeaking on the GEN 2 Wheelchair, How to fix squeaking on the GEN 2 Wheelchair: 手順 1、 3の画像 2 How to fix squeaking on the GEN 2 Wheelchair, How to fix squeaking on the GEN 2 Wheelchair: 手順 1、 3の画像 3
    • Locate the source of the squeaking.
    • Typically, this will be one of the rear wheels, castor wheels, or brakes.
    • Clean and remove any dirt or rust from the source of the squeaking.
    • You may need to partially disassemble the squeaking part in order to thoroughly clean it.
  2. How to fix squeaking on the GEN 2 Wheelchair: 手順 2、 1の画像 1
    • Check for improper assembly.
    • Refer to the teardown to check that the wheelchair is properly assembled.
    • Check for proper lubrication. If not lubricated, lubricate thoroughly with bike grease.
  3. How to fix squeaking on the GEN 2 Wheelchair: 手順 3、 1の画像 1
    • Check to see if the squeaking has stopped by rolling the wheelchair around.
    • If the squeaking continues, recheck the chair thoroughly to locate the problem. Once located, repeat the steps until squeaking has stopped.
終わりに
Squeaking can be caused by overly tightened connections. If problem still occurs after going through steps, try to slightly loosen bolts (half a turn of the wrench) near the source of squeaking.
ある他の人がこのガイドを完成しました。
作成者
9人の作成者と共同で作成されました。
Kali Slaughter
メンバー登録日: 04/19/13
207 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 14-8, Maness Spring 2013 Cal Poly, Team 14-8, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S14G8
5 メンバー
7のガイドは作成済み
コメント 1 件
A quick spray of Extralube C60 Trigger Spray will keep the components rust free and spinning for much longer... worth a go www.team-zx1.com
sandraphleb - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 11
今までの合計 3,360
